4.30 Gears from 2011 F450 for trade!
Ive seen a few posts on here about folks looking for these gears and our new truck has em on em and we would actually prefer something around a 3.70 range. If anybody on here has that set and would like to swap gears please let me know!
Thanks, Derek P.S. We are in the Los Angeles and Las Vegas areas on a regular basis. |
i dont need them, but 2wd or 4wd? (1 or 2 sets?)
Originally Posted by spinella
(Post 9766412)
Originally Posted by MB Classics
(Post 9766076)
I believe the F450 only comes in 4WD. Either way the OP should open up a classified in the classifieds section. |
The F450 are available in 2wd/4wd Cab Chassis, and 4wd pickup models. The cab & chassis uses the big Dana 110 axle in the rear, I believe they both use the Dana 60 front axles, with at least the cab & chassis using the Super 60 series. You should be more specific as to what you have! Saying 2011 F450 is very vague.
What engine do you have and what is the trucks intended use? You may regret the gear change down the road, and it will take thousands of miles of fuel savings to offset the cost of a gear swap.
The 450/550s and any Super Duty with 4.30s will have a Super 60 front. My F250 does.
