1986 F-150 specs
I have a 1986 F-150 4x4 w/302 FI and i was wondering what the standard axels were and what kind of gearing they had because im thinking of putting lockers and maybe different gearing in it.
1986 F-150 specs
You would have a Dana 44 Twin Traction Beam in front. In back, it's probably the 8.8" Ford, but a 9" is possible. The 8.8" has a removable cover, 9" doesn't. Look for a tag on the diff for the gearing, or just post the axle code from the door jamb sticker and we can decode it. That's assuming the gears are still factory.
1986 F-150 specs
is it possible to have almost a independent front suspension because thats what it looks like to me....although im not an expert thats why im asking
1986 F-150 specs
Yeah, that's what the twin traction beam (TTB) is. I guess you could say it's a D44 chopped in half that pivots at the center. This setup was used from 80-96 on 1/2 and 3/4 ton trucks, except heavy duty 3/4 tons used a Dana 50 ttb.
