Aligment Specifications
Does anyone have the alignment specs for a 99 f-350 4x4 crew cab SRW? I have an old laser alignment setup and I was going to check it, but I'm not sure what the toe should be. Or does any one have any recommended settings that may be better then the factory settings? Thanks in advance.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top colSpan=4 align=left>Alignment Specifications — F-250 and F-350, 4x4</TD></TR><TR><TD vAlign=top align=left>Caster @ Curb Ride Height</TD><TD vAlign=top align=middle>3.5° ± 2°</TD><TD vAlign=top align=middle>3.5° ± 2°</TD><TD vAlign=top align=middle>0° ± 1°</TD></TR><TR><TD vAlign=top align=left>Camber @ Curb Ride Height</TD><TD vAlign=top align=middle>0.25° ± 1°</TD><TD vAlign=top align=middle>0.25° ± 1°</TD><TD vAlign=top align=middle>0° ± 1°</TD></TR><TR><TD vAlign=top align=left>Toe @ Curb Ride Height (Positive Value Is Toe-In, Negative Value Is Toe-Out)</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>0.03° ± 0.25°</TD></TR><TR><TD vAlign=top align=left>Steering Axis Inclination (SAI) @ Full Load</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>8.5°</TD></TR><TR><TD vAlign=top align=left>Included Angle @ Full Load</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>8.5°</TD></TR></TBODY></TABLE>
That's perfect, Thanks!
2009 SRW 4x4
Dealer image shows 2008-2011 F350 4x4 SRW being the same. My local dealer has my truck and is doing an alignment. It's never been done in 85000 miles. They are replacing the steering box and recommended an alignment. Since, it had never been done, I decided to do it. After checking, he says they need me to buy a shim kit in order to get the alignment into specs. The truck is completely stock. Says the shim kit is $80 PLUS installation. He sent me a pic of the current alignment: FRONT CAMBER: L 0.4 R 0.2 * in the green range CASTER: L 4.1 R 3.9 * both in red as alignment range is up to 3.9 deg TOE: L 0.17 R 0.19 * left is green and right is red as range is up to .18 deg All values positive. Is already charging me $180 for the alignment which I think is ridiculous. Why would a stock engine need a shim kit to align it? |
