Ford F-Series Daily Drivers
I'm just wondering how long it will be feasible to drive this pickups as daily drivers. I'm calculating out costs and wondering if it would be better to get it running and spend my fun money on a newer pickup?
My projected expenses are: 35 inch tires and new 8lug rims $1000-1500 New Master Cylinder and Break Booster-$100 New weather strip all around $100-200 Oil change/filter-$20 Coolant flush and fill-$20 New hoses/belts-$50-$100 New brakes disc front, drum rear-$100-$200? Re grease hubs,bearings,and trans-$30 New suspension bushings-$20-$100 New air filter and plugs-$20 Sem paint interior-$ unknown New wipers $10? New washer fluid pump-$10-$20 New tailgate-$20-$100 Rust bullet/rust to primer convertor uncarriage/wheel wells-$50? Sand, prime and paint the truck ( Hugger orange)-$500 Herculine the floors, bed and rails, undercarriage, wheel wells, lower doors, and lower fender pieces-$100-$200 Seat covers front and rear-$50-$100 New thermostat-$20 Carb rebuild $100 New in tank pumps and sending units-$250 Ideal list depending upon funds: Rebuild/Rebuild kit for my 460. $500-$1500. ZF trans swap-$500-$700 4 inch lift kit-$600-$1000(First priority after good running) New seats/console-$200-$500 White gauge faces-$20 Tach cluster-$20 Winch-$200-$700 New exhaust with cherry bomb duals-$100-$400 Dana 60 solid front swap-$500-$1000( Pry last priority) Projecter headlight kit-$100-$300( A maybe) Cab lights/sun visor $200 More kcs for winch bumper,and rack-$100-$500 Inverter $30? New headunit(Either remove and sell old unit, or simply run an ipod tape connection) $20-$200 New Pioneer Speakers-$30-$100 Double roller tchain-$50? Rv crankshaft/camshaft?-$200? Steering stabilzers dual-$200 Electric fan-$30-$100( Maybe depending upon mpg) LSD in rear-$300? I figure roughly even with my ideal mods my pickup will cost me $5000 total, including purchase price. All work will be done in house, by myself, friends and mechanic/welder uncle so labor costs are nonexistent. I see it like this. I can buy a vanillaish newer truck for pry $5000 dollars. Insurance will run higher, and I will still have those set costs including fuel With the 84 upgraded in this manner, I will save roughly $80 bucks a month in insurance over my present dd. More over new rigs as I can't pay full price in cash. I will have the satisfaction of knowing everything about my pickup, and make it the way I want. Is it ever feasible that these rigs will cease to be good daily drivers? I'm not meaning in terms of gas mileage but in terms of them being so old they are not feasible in the next 10-20 years? Anyway, just kinda was hoping for some ideas of expertise here. |
Some of things you listed could be bought used to save you some money. I'd poke around Craigslist, eBay, and local off road forums to see what is available through private parties (tires, lift, rims, etc). You many also try checking out local JY and seeing what they have. Sometimes you get lucky and find some good stuff.
As far as a newer truck, how much newer? If you go 97+ and want to lift the truck, expect to pay more for a lift. Parts are going to be more expensive (a reman starter for my '00 is $140 vs. $50 for my old girl). Diagnostics will be a little tricker then what you have now. I dunno, I could probably go on and on about why you should keep your old truck. I don't think these will ever fall out of being a good dd. Aftermarket support is there and with the production numbers I don't think it'll be a problem in the future. Try owning a 1gA (which is 1990-91) Talon/Eclipse/Laser and you'll see a vehicle that isn't a very good future driver... no, a 1987 Nissan Pulsar NX SE DOHC 1.6L, one year motor, and you'll see a VERY unfeasable daily driver. I've owned both and have lived with the PITA issues involved with trying to find parts that are obselet and you can't find to save your life. And come on... older trucks are cool. https://www.ford-trucks.com/forums/p...ictureid=53464 Neat car, damn near impossible to find parts for it. |
Yeah, that is the plan. Get whatever I can used, but in good condition. I honestly hate the look of all the new trucks. I wouldn't go much newer than the 03 powerstroke Fords those are damn nice. Likewise for the other makers, but really I dislike chev trucks the most. Yeah I plan to also check junkyards, as we have a lot in the nw and if I look around pry get a good deal. Appreciate the advice!
this is what ive done to my dd....
hey
this is what ive done to my dd what was fixed on the truck i dint do it all but damm close! ------------------------------------ wiper pump stereo speaker left door locks truck cap removed and repainted seafoam in gas radiator hoses fan belts heater hoses new battery clamps repaired underhood wiring fixedcab holes flushed radiator/replaced coolant painted front grill fixed rearview mirror brake lines/hoses - all windshield sqiuter replaced entire parking brake system rear brake pads,drums,springs,whl. cyl. replace headlight-right side right turn signal,not bulb replaced horn lic plate lite bed repaied small holes welded and painted rear bumper replace bumber bracket repaired tailgate lock welded tailgate/bed-loose tailgate replaced hood replaced battery hold down made a battery mount fixed lighter steering box adjusted front calipers frt. wheelbearings replaced packed hubs with grease replace frt. brake hoses. frt.brake pads turn / replaced rotors radius arm mount- dr. side radius arm bushings replace clutch/pressplate & brg exhaust manifolds- and pipes exhaust system -cherry bomb glass packs steering-tierod and center link shocks-all replaced spark plugs motorcraft installed brush guard with lights replaced radio antenna new wheels chrome factory made air pump bracket- new stereo new alt new voltage regulator sun pro tach installed grill guard with lights 8 ball shift knob installed a 1969 351w replaced valve stem seals timing chain oil pick up tube new oil pan rebuilt auto lite 2100 carb put on manual choke new freeze plugs new flywheel holley by pass regulator (went from efi sd to carb) water pump new points cap cond rotor plug wires painted engine pilot brg welded frame at spring mounts rear new thermostat drop in bed liner new trans mount replaced fuel lines new oil pressure sending unit custom dip stick tube removed smog equip deezee aluminum bed box new rear shock mounts truck runs real good with the 69 351w 9.5 compression regular gas amazing that the factory 2v carb is only 356 cfm! 4v someday soon cold blooded on -5 f starts with manual choke..go figure! but starts everytime. got the t 18 trans with 4x4 (base model) got about 4000.00 in it interior need a little work... |
There is no real limit on how long you can make these things run. Most of the mechanicals are simple enough to work on, and given the history of volume of sales when new and the parts market, replacements should be fairly well available for quite a while to come (albiet OEM parts will get harder to find). Most of the anoying problems like the balky gauges, weak headlights, etc) can be upgraded with relative ease. The real limiting factor I see for these trucks are rust and metal fatigue, especially with the frames. I've got about $10K into mine, but it's built to run for the next 15-20 years, including an engine rebuild, trans/transfer case rebuild, and essentially a frame off freshening. It was a bit of cash up front, but it's a heck of a lot cheaper than spending $30K for the same capability, plus I had fun doing it.
Was the truck a feasible and reliable DD when it was new? SURE! The problem with older vehicles is that they get...well, old. Even a newer truck gets old. When things get old, problems arise and things need to be fixed. Will you be able to find parts for these trucks in the future? SURE! look how many are around. Granted, it may be hard to find some parts if you are doing a 100% correct restoration, but who's doing that anyway. If you do all you're planned work, take care of it like you will right after you've done all this work, repair problems as they arise...you're truck can last forever. If a part truly does become unavailable, there will be some modification or upgrade that you can do to get it back on the road.
Also, that $80 a month will add up over time and a 'newer' truck will need a few things repaired pretty soon and you'll still want to do some things such as upgrades. |
A Bird in the Hand is Worth Two in the Bush.
A mans' hoss is always gonna need new shoes/feed&water/occasional medical attention/curried/exercised/a comfortable stall/new tack when the old wears out. All that for the express purpose to take you there and back. Eventually he is gonna give out and be retired. Our modern mechanical horses are very similar, except they can go on forever with same TLC given to it's organic forebearers. My '81 F100 is not old. It has been my faithful companion since the day we drove off the lot waving goodbye forever to the dealership. All it has taken over 30yrs worth of daily driving was a little TLC. Someone is gonna get a hellofa hoss when I...... |
Some of those things you have listed there are routine maintenance items and will
(eventually) need to be done to ANY vehicle you own. I do what I do to my truck mostly because it's fun, I spend my working days in computers & hi-tech and need something mechanical in my life and this truck fulfills that need, I don't do this cuz it's a classic truck and worth a lot of money or anything. Much of the stuff I get comes from junk yards and Craig's List and is pretty inexpensive but availability is hit-or-miss and ya sometimes have to buy things when you weren't planning simply because the opportunity arose and is "too good to pass up." As for feasibility & availability of parts, take a look at rockauto.com and see what's available for '70s & '60s vehicles (particularly vehicles with cult-like followings, e.g. Mustangs Camaros Corvettes and maybe just for grins see what you can still get for a 1970 AMC Hornet and what the costs are) and use that to help you see into the future. In any event, remember that the F-series was the #1 selling vehicle for something like 30 years and has got the largest aftermarket in the automobile industry. |
Look, someone already gave your truck its first ding or two or even twenty. A new truck depreciates and is still just a tool. The biggest problem I have found is there is a stigma of driving an old truck (especially around here where so people in this area of the country are status driven). Realistically, the only problem I ever had with my last Ford, 1986 F250, was a wire popping off of the coil, an issue that would have not even happened had I left well enough alone and not replaced the perfectly fine coil. If you like it, drive it daily. You can upgrade it along the way and there is less cash outlay.
Spend what feels right to you on it. I'm keeping a eye out for 86 crew cabs and when I can swing a job and a place to park it, it's mine. I figure then I will probably be sinking a butt load of cash into it, and it's MINE.
Can you picture yourself driving it until you keel over and it becomes part of your estate? Then go balls out on whatever you want. It's worth what you spend on it to you, not what the marketplace/either people say. I figure if I spent $50k or something restoring the truck i'm after, and it's only worth $2k on a good day, not my problem. I'll love it until my last breath is taken, and that is all that matters! The way I see it also is that the truck is still at a point where most of the parts it needs can be acquired. better to start a "restoration" at this point and time, rather then waiting another 20 years, just to find out goverment regulations have closed up the ability to restore it, and the aftermarket or even ford has quit making needed parts for it. Battery cables on a 93 F150 seem to be a perfect example of this. It will reach a point that ford will just quit making them, and you are up ***** creek on OEM replacements if you desire that stock look/need it. Good luck, I hope your truck brings you much happiness once you decide! Maybe I see you someday at a car/truck show with it |
Thanks for the advice everyone! I figure I'll go about doing this as all the costs are small compared to a new one. Really the only way I would afford is a loan like everyone else and I don't want to owe anything to anyone, that I can avoid. A couple quick questions.
A HID/Projector set for my pickup, is reasonable around 80 off of ebay. Would I run into any issues with too much wiring draw, burning out my stock harness? Another alternative is to use sylvania ultra stars or whatever those bright bulbs are, but haven't checked into availability. Secondly, I plan to run rust bullet or another rust to primer convertor on everything I can. Its not a rust issue presently, but I figure I'd rather do it now before I have to start cutting stuff down the road. On top of this I want to run herculiner with the uv protection. I have heard that this isn't the best option as the coating can get scratched or torn and ripped open, thus allowing water to get trapped. Any validity to this assumption, or better way to do this? |
HID....I would not use the OE wiring for any part of it. I'd use complete new system and just fold the OE wiring out of the way. The UlltraStars are very good. I've installed them on both my truck and car. Far and away.....is how the UltraStars help you see stuff.
From my understanding, the HID's do not seem to work as well on a vehicle not originally running them (wiring aside). Some of the aftermarket stuff also does not let you keep high beams. I would run the headlight relay and some Ultra Stars.
Skip the HIDs they are illegal and 90% of the time blind on coming drivers. Look into LMC for their "euro" headlights and H4 bulbs. they make a night and day difference. I would also look into their headlight harness too. I am more than pleased with them on my 86
Have you read this: Whiter Whites, Brighter Brights .: Articles I did that and silverstars (I think thats what I bought anyway)... Very happy with the results.
