2000 Ford Expedition Ticking/ tapping in under the hood
I have a ticking/ tapping sound in my SUV. Does anyone have any clue what could possibly the problem? Help Please
It could be several things like a fuel injector, a valve lifter, a solenoid, a spark jumping to ground, and exhaust leak, etc. You need to try and narrow down where it's coming from for us to be able to give you guidance.
it is a consistant ticking sound from the engine.
Originally Posted by singr_69
(Post 9704174)
it is a consistent ticking sound from the engine.
You've got to give us something to go on, we're not there, you are. |
sorry. Top. and it is constant doesnt change when idleing up or down
I've got the same thing. You can't hear it from inside. Mine goes tap ..... tap tap ..... tap ..... tap tap. The sound is almost like a AC compressor engaging and dis-engaging and I can't tell where on the motor it's coming from.
(Post 9703752)
Originally Posted by Moto Mel
(Post 9708665)
Check your email.
I only have a guess that no one would want to hear. I live near Singr and might be able to ID the problem for him. I don't have a shop and I don't work on other people's stuff either. I do have a lot of tools though.
All you could do is make a wild guess from what we have been told so far.
Guys, there are a hundred moving parts under the hood, to say it is ticking doesn't help... Does it go away once the engine has warmed up? Is the rate of ticking related to the rpm? Could be the exhaust manifold leaking, that usually goes away when warm unless it has been doing it for a long time. Could be a spark plug getting ready to blow out Could just be the typical cold engine noise most of these engines make. Fuel injectors are apretty soft tick, usually not heard with the hood closed. Timing chain tensioners could be bad leading to several different noises. So short of someone like Mel offering to come take a listen, you are going to have to help narrow it down on your end before anybody can be much help here. |
'05 EXPY 4x4 105k here.. I'm not a professional, but here is my experience. Had a ticking sound under the hood.. Was a constant sound.... Sound was on top half, on passenger side.. Also was sluggish.. Brought it to a local independent guy who was able to diagnosis and repair it. The timing chain tensioners were disintegrating and the bits of plastic were clogging the flow of of oil into the passenger side of the engine.. So we replaced the timing chains, tensioners and associated parts that were jammed with plastic from the originals, and voila ticking sound was gone, and performance improved. Not sure this is your engines issue. but just a possibility based on my experience.. Good luck !
Originally Posted by aft2005exp
(Post 9710963)
what about ticking sound when cold goes away if you rev or once warmed up....lifter?if so does seafoam or lucas usually fix this or do i have to dig in?
If you have a light ticking sound when first starting that goes away after a few seconds it is usually the cam chain tensioners. If it only goes away when you rev the engine there are usually other problems to be addressed.
it is just light ticking...sounds like the older cars when you needed to adjust rocker arms
