53-56 Front sheet metal alignment procedure
I've posted this a couple times as replies to different topics about aligning the front sheet metal, but it's hard to find by searching and you have to read thru many posts to find it. I keep getting requests for the procedure, therefore I've decided to post it to it's own topic to make future searches more sucessful.
My suggestion: Most try to align the rest, then do the hood. As stated above the hood is aligned first then the rest of the front clip is aligned to it. First I will assume the frame to cab mounts are in good condition with good rubber and cab mounted straight. You'll never get the front right if the cab is crooked.
Hope it helps! Chuck <!-- / message --> |
Sam, I tried to copy and paste your edited format, but the bullets didn't copy as you can see. I don't know how to get them to appear.
Thanks gor the re-post:-X22
Originally Posted by AXracer
(Post 9684251)
sent Sam |
Worked that time! Thanks for the editing, I'm sure it will make it easier to follow.
Only one small glitch I have found. Chuck, you have no gallery titled "Misc".
Edit: Oh, I get it now. The gallery is sdetweil's . Doh!!! Edit: Nope, not there. Wrong again. |
Originally Posted by BACAGrizz
(Post 9684393)
Thank you. Very good instructions.
Thanks for the repost , I tried searching for it once, but had no luck.Greatly appreciated!
Always glad to be of service.
That hidden pivot on the hinge being free is critical to the correct operation of the hood. The hood will go up and down with that pivot stiff/frozen but will not pull down at the cowl properly. |
ax racer just wondering how you would tighten the support rods or put hood hinges on when apparentli if i read your post correct the hood is still setting on the truck unhingrd.. just wondering thanks ax
should read hood unhinged
Attach the hood hinges to hold the hood alignment once it is set. Test to be sure hood opens and closes to same cowl alignment before continuing with adding and aligning additional sheet metal. Sorry if I didn't make that clear.
AX,
As always, your stuff is incredibly informative. I only wish I was at this stage... (though I DO see it in happening this spring... maybe.) |
Chuck,
Thanks for posting the suggested procedure! It copied perfectly into OpenOffice..... http://www.openoffice.org/ Cheers, Rick |
