oil cooler leaking
ok i have seen some oil spot latly, and looked under my truck the front of the cooler is covered with oil and the 2 front lines going in it, the rest looks clesan as well as the top lines, i was it off and same thing, to day i seen a little antifreez in the oil so must be getting wors, can i use a sd oil coler ? are thes a pain to rebuild and replace, looks like 4 lines and 4 bolts, is there a good place to get orings or a new cooler? any picks would be a big help thanks guys!!!
You can buy the rebuild kits from riffraff or dieselorings.
Messy, but something you can do yourself. New coolers are very pricey, the rebuild kits are around $60. |
Are you sure your looking at the oil cooler? Last I checked the oil cooler has no lines going to it..
Originally Posted by BadDogPSD
(Post 9663998)
Originally Posted by strokin'_tatsch
(Post 9664212)
Here's a couple of how-to write ups... everything I do seems to take twice as long and cost twice as much!!!
7.3 oil cooler rebuild - TRT Home Oil Cooler O-ring replacement R and R - Powerstroke Nation |
Your oil cooler should have nothing running to it except for the block heater cord on the back oil cooler cap... You can use an oil cooler from a '94.5-'03.
Get a rebuild kit from Clay. He gave you a link to them in his reply above. |
(Post 9664721)
Nope, no gain in the SD cooler...
(Post 9665963)
Just checked over at powerstrokehelp...SD oil cooler helps gain 30hp over stock. :-X14
Originally Posted by Krisx125
(Post 9666064)
