96 f-350 no odometer
my odometer numbers dont show up, what is the cause and how is it fixed? thanks.
You may have a bad fuse, it would be fuse #8 or #18 in you cab fuse panel.
I could also be a bad ribbon cable or PSOM. http://i54.photobucket.com/albums/g9...2FusePanel.jpg / |
is it sifting really hard to? if so its the fuse. had this happen to me scared the living sh*! out of me. haha good luck
got truck all together, still no odometer, all fuses check out ok. how do i determine between ribbon cable or psom. took the dash apart and when u touch the cable some numbers start to appear but instantly go away.
