Ford Truck Enthusiasts Forums
-   4 Cylinder Engines (https://www.ford-trucks.com/forums/forum58/)
-   -   It worked for me on 2.3 (https://www.ford-trucks.com/forums/101617-it-worked-for-me-on-2-3-a.html)
big1 03-02-2003 09:01 AM
When my 92 Ranger 2.3 had nearly 170,000 mile's I dicided to rebuild it. (It was getting tired) I did all the usual thing's like .030 over bore, machined the crank, reconditioned the rod's, new cam & follower's, you know the routine.But I went a little further by using Forged piston's, "Moly" ring's, and slightly larger cam. Had the block, head decked a total of .040. When I started driving it I got a " Check Engine" light. The code said it was running lean. After adding larger injector's ( 4lb's) got another light saying it was rich. After talking to a few racing friend's I installed an adjustable pressure regulator and upped the pressure by 4 lb's, and now the truck run's great with more power and fantastic milage.( nearly 33mpg on open road)
robyr 03-20-2003 11:29 AM
big1 just curious how much your overhaul cost ? I have a '94 ranger with 180000 miles.
mcjackson 03-21-2003 02:02 PM
I'm looking to do the same thing to my 89 2.3 . Want to tow a 6 x 10 enclosed trailer, for go karts. Who has the best choice of parts, especially a better towing cam?
Thanks,
Mike
DainBramage 03-22-2003 02:04 AM
I think you'll find that Racer Walsh is the best way to go.
mcjackson 03-22-2003 02:57 AM
Who? Do they have a webb site?:confused:
