Driver Seat presets button
I went to push in one of the driver seat preset buttons (on the side of the seat and it says "SET" "1" or "2"), and the entire unit came unfastened and pushed/recessed into the plastic housing of the chair. It is visible, but my fingers can't get a grip to pull it back. Is there a quick way to pop off the side plastic of the front chair? or will the entire chair have to come off/out to get that secured back into place? Any thoughts?
Thanx. Tj |
I believe that whole plastic shroud comes off in pieces. Like the front of the chair and rear of the chair comes off and then I bet you will see some screws on the sides.
The plastic panel on the side of the seat is held in by clips (no screws) . Just be careful when prying cause the plastic tabs can break easily
Originally Posted by Blacknav
(Post 9636817)
Nonetheless, thanx for the help. I got it locked back in place and I'm in business again! Tj. |
