Rear window struts
Hi all,
Anyone know how to get the struts off the rear window of a 2002 excursion? Thanks! |
Yes. You can use a small screwdriver to pry the spring like clip at each end of the gas spring. As you lift or pry the clip out and away from the ball joint connection you will be able to pull the strut off the ball end on the hatch or door frame. Both ends are similar.
Just a note about these struts if you have a 4X4 and you would like the hatch to open a little higher, say 4 or 5 inches you can order the struts meant for the two wheel drive Excursion from Ford. |
Be careful when you remove them. Hold the window up with one hand while you remove the strut one at a time. When you pull one strut out, the window will fall down on your head if you don't support it. One strut is not strong enough to support it.
It's best to have some other person hold it for you. Good luck. |
Amen on it's heavy !!!!
I used a 2x4 for support when I replaced mine.... |
Replaced mine on the 4X4 wiht the longer ones (for the 2WD version) last Fridayl. Much better. That glas is HEAVY to be careful.
Also I've bee having "door open" indicator issues with the liftgate switch whic his in the latch on the Driver side. I solved the probme wiht a bit of WD-40 sprayed on the latch from inside and then adjusting the latch bar on the truck. Makes for a solid fit now and no more "Door Open" light!!! If your gets flackey, ajdust the latch first as the rubber gaskets taek a set "crushed" in the colder weather. D |
As always everyone thanks for all the help!
I have to ask, because people are calling me "ridiculous" when I offer my opinion as to why there would be different struts for the 2 wheel and 4 wheel version. So why on G-d's green earth did they make different rear window struts for the 2 wheel and 4 wheel versions? Oh in case anyone here would like to call me ridiculous, I said "They likely made two versions as the 2 wheel drive sits lower than the 4 wheel drive which necessitates having the rear hatch go up higher or it would hit the average person in the head even open." Seemed 100% reasonable to me.... but others say "RIDICULOUS!" |
Originally Posted by XbigXredX
(Post 9566662)
4wd struts might be shorter so the open liftgate doesn't
hit the celing in a typical 7' garage - or be too tall for the standard soccer mom to reach. Just speculating.. |
The 4WD Strong Arms are shorter to keep the "open height" (when measured from the ground) close to the same as when the 2WD liftgate is opened.
My wife is only 5' 2" and since i changed the Strong Arms out for the lonre ones on myu 4WD, she has to tippy-toe or jump to reach the handle when the lift-gate is open now. But at leat it does not hit me in the head now!!!!! D |
So I am correct that the 2wd drive Excursion sits lower to the ground, or that the 4 wheel drive sits higher, whichever way you want to look at it.
I can't find any specifications that indicate this, but I kind of presumed it would make sense. And making them open higher sounds good to me as I constantly hit my head on them now. To the guys that did the change, any idea how much higher it is now? 3-4 inches or is it more? |
Here's a video Mike did over here on an Excursion tailgate. It'll give you an idea on how the glass ones pop off too.
We carry the Ford Excursion tailgate struts Hope this helps, Tony;) YouTube - 1AAuto.com Install Replace Tailgate Lift Support Strut Ford Expedition 1997-02 |
AWESOME!
That's all I can say, that video couldn't show it any simpler! Just AWESOME! :-X25 |
wow great video! that guy in it looks crazy! i need to get the 2wd ones!
anyone know the partnumber for the 2wd versions? |
As stated earlier, once I replaced mine with the two wheel drive versions, my wife couldn't reach the hatch anymore, she has to stand on the hitch to reach it.
You can fix that by adding a simple leather strap that hangs down from the liftgate, or buy one from another vehicle ...
Your wife will love you again ! |
