88 F-150 6 banger exhaust leak
I just went through the trouble of replacing my intake/exhaust gasket, trying to fix an exhaust manifold leak and that sucker still leaks! Any tricks or ideas to eliminate this?
Thanks! |
Did you check to make sure your manifold isn't warped? Take a good straight edge and check your manifold and head.
The head and the exhaust manifolds (there are 2 manifolds on this engine) were fine. One manifold had a small crack right in the middle but I'm getting very little, if any leakage from it. I guess I'm going to have to take the inner fender out again and see if I can tell where it's leaking; it shouldn't be too hard because I powdercoated my manifolds silver before I put them on. Thanks for replying.
