P/W P/D wiring diagram???
I need the wiring diagrams for the power windows and locks in a crew cab. My back two windows don't work and only one of the back locks works.
Clear easy to read pictures would help me SO much... Need to figure this out so I can replace motors if needed. |
try over in the 1987-1996 forum, pwr window and locks would be the same as gas engine
you could pull door panels and test motors with a 12v source straight to the motor
i had to pull my rear lock motors and free them up by hand with pb blaster. when you hit the window button... see if the volt gauge drops a little, this will tell you if a motor is stuck.
I'm pretty sure at least one motor is stuck. I can hear it trying to work...
