will Jeep wheels fit on a F-150?
I found a deal on a set of 35x12.5x15 wheels and tires. Does anyone know if jeep 5 lug wheels will fit on a ford 5 lug? Thanks!
The early Jeeps use the same bolt pattern but the wheel offset is often all wrong for our trucks. You want a maximum of 4" backspacing for our trucks, that equates to 0 offset on an 8" wheel and -2" offset on a 10" wheel.
yeah i have a set of older jeep wheels on my truck now. just make sure they measure out to be 5x5.5" and youre set
like others have said, they have to be older. the bolt pattern for our trucks is 5x5.5, while the "newer" jeep wheels if you will are 5x4.5.... i believe the 5 lug dodge wheels fit our too...
up to and including 86 jeep wheels fit(5 on 5.5 bolt pattern)
87 and newer jeep wheels are ranger pattern(5 on 4.5) |
87-96 are 5 on 4.5 as well (I have a YJ)
From what I have heard if its a NEW jeep as in the JK model, those are 5 on 5.5 as well.... but don't quote me on that. |
Originally Posted by Samsonitesamsonite
(Post 9497495)
Originally Posted by Chicken_Fried
(Post 9497550)
You are correct. Most of the new Jeeps are 5x5.5"
also not that you can get adapters for damn near anything..
Originally Posted by fishforlife2007
(Post 9499774)
Thanks for the info. They were off a 2002 Jeep so they wouldn't fit. At least it saved me a 3 hour drive to check them out.
Wheel options
I know the suzuki sami 5 lugs will fit a 79 bronco. No back space issues. I bought them 12 years ago. They are 15x10.
I've heard some of the dodge trucks will fit but what years? Is there some place in a sticky that breaks down a list of what other things will fit a 5x5.5? |
What vehicles have 17" wheels with the 5x5.5 bolt pattern? I would like to move up to a 17x10 if possible but I am cheap and want to use a stock wheel and not aftermarket if possible. What back spacing should these be?
Guys I have an expedition.
Originally Posted by Newenglandfordjunkie
(Post 9495578)
