GAS TANKS !!!
I got a biiiiig hole in mine .... will one off a pickup truck fit?? from 87 to ... 91 ? or are they the same up to 96????
It will be way smaller than the original one, why don't you try to get a plastic one from JBG? or a junkyard?.
Originally Posted by Encho
(Post 9433008)
There's a picture of one in my garage. What happened to the skid plate?
The bronco has a 32 gallon tank, all the trucks, vans or motorhomes with a aft of rear axle tank have smaller tanks. So you'd first have to find a vehicle with two tanks, then you'd have to modify the filler neck and the support straps/skid plate. Then the gas gauge might not read correctly.
Solving a problem by not fixing the problem while creating more problems is not in my mind fixing the problem. |
Originally Posted by g_k50
(Post 9433392)
Their all the same except the bronco is deeper. So just take a cut off wheel and slice off the bottom (with the rust) and do the same on a junkyard tank and then weld the good bottom on to your Bronco top.
Just kidding LOL. |
Originally Posted by helirich
(Post 9434833)
Just kidding LOL. lol.......... |
(Post 9434833)
Just kidding LOL. |
Welding tanks is a pain, I'm not that steady of a welder.. heh
Now brazing, that I could do nicely. p.s. Don't forget to wear a respirator or use a big fan, because the galvanizing is toxic as hell when you burn it. |
bought a new one this morning..... installed and on the road again lol, thanks anyways guys
