Ok yeah all timing marks are good thank you for helping me i just wanted to double check!
Originally Posted by RoyalFord
(Post 10212574)
I started up the truck last night after replacing the drivers side head gasket... she is purring like a kitten! I guess I got the timing correct :)
I appreciate all the help again guys! |
Originally Posted by 70f100longbed
(Post 5714734)
Here is how to time a 5.4:
If you can't see the gold links on the chain lay it on a table and stretch it out like this ========= at one end the link will be like l and the other end will be = . Mark all 3 links with white paint or something that will not rub off. These are your timing marks. Turn the crank so the key is at 12 o-clock and there will be a line on the crank sprocket at 7 o-clock. Set the left cam timing mark to 12 o-clock and the rt cam to 11 o-clock. Install the straight guides and the left chain first placing the single white link on the crank mark and the double white links on either side of the cam mark. Repeat for the right side then install the tensioner arms and then the tensioners. You need to compress the tensioners before you can install them. Stick a small screwdriver in the lock to release it and push in the plunger. Then push in the small ratchet arm and insert a small pin or paper clip into the hole to hold the tensioner retracted. Double-check the marks before you install the timing cover. DONT forget the crank sensor trigger wheel or you will be chasing a no-start concern (don't ask how I know LOL) |
Originally Posted by Jake349026
(Post 19006703)
So the crank mark is supposed to be at 7 not 6? Key at 10 not 1? I kept getting told 6 everywhere I look. I'm trying to do my 5.4 Triton 2valve. I had it once and put the tension bars on wrong sides n it jumped like 2 links fixed it and tried to turn it manually but I get 3/4 the way around and it seems like something is stopping me from going farther... any suggestions? All help appreciated
Originally Posted by Moto Mel
(Post 9046187)
If you send me your email address via PM I'll send the page on cam timing from my manual to you.
https://cimg2.ibsrv.net/gimg/www.for...07fa9e45bd.jpg https://cimg8.ibsrv.net/gimg/www.for...195f300a8a.jpg im to new a user to pm as far as I know but my emails jake349026@gmail.com |
I don't see were it's off all pictures are what I see online as examples
https://cimg2.ibsrv.net/gimg/www.for...07fa9e45bd.jpg https://cimg7.ibsrv.net/gimg/www.for...c3b5c62863.jpg for example of my timing job I just made a thread explaining my whole story of the job from the start if you wanted to look into it |
From the pics your timing is spot on. Just as long as the driver's side chain mark is on the crank dot directly behind the passenger side then its right.
It is on the mark so I guess I have bent a valve I'm trying to get the exhaust manifold off to pull the valve and replace them any tips?
You have to pull the cylinder head to replace the valve.
Ik I'm removing the exhaust manifold to get them out of the way but it's a tight fit for the bottom bolts
(Post 19022153)
I wish I had done it that way, the bolts on the flex connection was refusing to move when I tried that. But I will do that when I put it back in I'll break the bolt sandreplace them if necessary.. I got it tho atleast driver side. Anyone have any advice for removing valve stems from the springs without the special tools if possible?
And the person who told me how to get to them said I had to remove the manifold to remove it I wasn't sure if the bottom bolts was in the head or the engine block at the time
cam / crank timing
(Post 9046187)
A copy of your timing page would be great. managerlcam@gmail.com |
