Your right, the FUN never ends!
Pulled the rear tank. Going to tackle the sending unit stuff and fill neck tomorrow. Also need to cut the welds on my bumper brackets.. :-banghead
https://cimg6.ibsrv.net/gimg/www.for...cb27dae835.jpg https://cimg1.ibsrv.net/gimg/www.for...8c59a8f445.jpg https://cimg4.ibsrv.net/gimg/www.for...aa6192afc4.jpg https://cimg5.ibsrv.net/gimg/www.for...57521719c4.jpg |
That looks like ZERO fun.
Originally Posted by BBslider001
(Post 19465932)
Originally Posted by Khan
(Post 19465963)
Fixing hacks never are, but I'm hoping it goes smooth. Today is basically not fun in general. Cutting that thing out of the fill tube, cutting welds and doing tank work.
Lame update. Added a 3/4" PEX ball valve to my supply line to cut off radiant heat in the cab. With it being a little cooler I can feel the heat coming through the vents. Ironically this truck had valves on the supply and return lines but they were seized up and hard to open.
https://cimg8.ibsrv.net/gimg/www.for...d907db8608.jpg https://cimg9.ibsrv.net/gimg/www.for...e533341067.jpg https://cimg0.ibsrv.net/gimg/www.for...8c40334935.jpg |
Where did you find the new washer fluid bottle?
Originally Posted by z31freakify
(Post 19519347)
(Post 19519355)
Pretty sure I ordered it from CP Addict. If I recall correctly it was roughly 40 dollars without the pump. I reused my pump, but I think there is an option for a pump for an extra 30 dollars or so.
I remember the time no one offered new coolant bottles what a mess that was lol. |
(Post 19519421)
Sweet. The one on my mule is dry rotted not leaking but great to know they make one.
(Post 19519606)
Mine wasn't leaking but I figured it wasn't a bad idea to replace it since I was changing to the degas style cooling system. Its a Motorcraft piece so I expect it to last another 20 years lol
(Post 19519726)
A few years back not even Motorcraft was available. I had to adapt an E series coolant bottle because only FoMoCo made the OBS coolant bottle and they were discontinued. Fun times.
Got some work done awhile back, life has gotten in the way of trying to install this tank. Will hopefully install tomorrow. After this is up I'll hang the spare under it and list the parts I used/ snap pics for everyone that's curious.
https://cimg1.ibsrv.net/gimg/www.for...ebe8021035.jpg https://cimg3.ibsrv.net/gimg/www.for...94af68b293.jpg Used a 90 degree fitting and bent to match supply line. Then bent another 90 degree off that and set at 12" long. This barely fits and is at the tank wall. https://cimg5.ibsrv.net/gimg/www.for...f952a88ae9.jpg Sending unit installed. |
Looks great bud! Nice work.
(Post 19530050)
Has Ike found a home yet or do you still have him? |
