Originally Posted by Björn
(Post 9348895)
Yes the truck is in the netherlands
http://94.100.120.165/1105200001-110...18_5_eYZm.jpeg http://94.100.116.101/1105200001-110...18_5_16M_.jpeg |
Good to see your truck made it OK. Looks like the PO was honest about it. From those pics, looks like nothing's missing. That article should arrive soon. I included some other reference material and mags you probably can't get over there. Good luck
Nice Zoot, I let you now when I got it
Got some parts out of the box https://i285.photobucket.com/albums/...345-border.jpg https://i285.photobucket.com/albums/...346-border.jpg |
sooo maybe i missed it, but what was the mysterious gadget in the glove box?
that is a box that makes differnt sounds
like bells/train/cow now its garbage |
(Post 9370718)
like bells/train/cow now its garbage.............Ibuzzard if that is it I will send it to you |
Nice looking truck! I see you live in the Nederlands....Cool, Where in Holland do you live?, I have lots of relitives there in Lelystad, and I was born in the haag, but I was very young. So I cant speak the language any more. Any how that is a great ride and Maybe someday I would like to see Holland and I will look you up. Da!
Originally Posted by ibuzzard
(Post 9370780)
But,you promised...........LOL!Actually,I'm proficient at making various barnyard noises in the seclusion of my truck,no electronic device necessary.
Originally Posted by SCRAPHEAP51
(Post 9370799)
And when you are in holland let me now |
Do you guys now, if you can make from a c6 tranny with floor shifter,
A Column Shift. |
Awesome build good job on the truck.
(Post 9401459)
A Column Shift. John |
(Post 9401957)
Yes you can, you will need to get a shift column and get a cable linkage from someone like www.lokar.com . www.ididit.com would likely be able to set you up also as well as www.flamingriver.com . You could likely use a doner column from another vehicle and get the linkage from one of the vendors mentioned but a new one would likely be a better choice. Hope this is of some help.
John I don't recommend the cable shifter linkage! I went that way and it never felt right. I couldn't get a feel for the shifting detents, it felf kind of mushy. I changed to a mechanical linkage with a kit from Lokar and everything "feels" right now. I can actually feel the shift positions and they don't move around. That was the other problem with the Ididit system, if you tightened the clamp too tight on the column it was hard to shift, too loose and it moved around some. I never did get it "just right". JMHO. |
Originally Posted by B/B ford
(Post 9402734)
I don't recommend the cable shifter linkage! I went that way and it never felt right. I couldn't get a feel for the shifting detents, it felt kind of mushy. I changed to a mechanical linkage with a kit from Lokar and everything "feels" right now. I can actually feel the shift positions and they don't move around. That was the other problem with the Ididit system, if you tightened the clamp too tight on the column it was hard to shift, too loose and it moved around some. I never did get it "just right". JMHO.
Glad to see your truck made it across the "big pond" okay. You made quite the commitment to get it that far. If you don't mind me asking, why do you want to get rid of the floor shift?
Thanks for the info guys
The reason that I want a column shifter I like a clean floor ,and when I have passengers ,they can’t hit(by mistake) the floor shifter |
