diff
yes it is embossed and i painted it i took the springs to peaces two leaves were snapped in two and some of the others werebits out of other trucks and maybe a tractor every thing was renewed clips bolts etc
https://cimg3.ibsrv.net/gimg/www.for...f293d8e4c2.jpg https://cimg4.ibsrv.net/gimg/www.for...f82d315279.jpg |
thanks
thank you for the feed back gentlemen it helps to keep me motivated but i do love working on it just wish the powder coater would hurry up
cheers Stuart |
Awesome good job Stuart. I should be doing the same thing to my rear spring packs. What did you use to remove the U-bolt nuts? I have 3/4" and 1" impact guns but don't have room to use them.
diff
yes i found it hard i used a tube socket and a brakerbar with a bit of pipe to get some tourke it took some time used half a can of wd40 to keep the temp down so good luck with yours
Welcome to the site. Following the progress on your truck. the big ones are fun to have.
thanks
Originally Posted by JimG1098
(Post 18312951)
cheers Stuart |
picked up
well i picked up the chassis
https://cimg6.ibsrv.net/gimg/www.for...80851755f6.jpg chassis https://cimg8.ibsrv.net/gimg/www.for...9823dc4946.jpg parts https://cimg0.ibsrv.net/gimg/www.for...1985696b56.jpg front end https://cimg1.ibsrv.net/gimg/www.for...90ae8614a1.jpg front drums from the powder coater and some other parts as well yahooo |
That frame looks great ! drums as well.
Thanks for sharing. Greg |
You are well on your way. Continued good luck
please help
i have picked up a flathead and i'm
https://cimg3.ibsrv.net/gimg/www.for...a86455f0de.jpg https://cimg4.ibsrv.net/gimg/www.for...1b1b0e2e7a.jpg https://cimg5.ibsrv.net/gimg/www.for...54272004bf.jpg https://cimg6.ibsrv.net/gimg/www.for...c0892aef26.jpg going to do it up its a 24 stud these are the numbers on the heads and what i can find on the bell housing i have no ides what the mean can any one please help me |
"6050 is the generic number for a cylinder head. 81 indicates that it was designed in 1938. Specifically that cylinder head was used on 38-42 trucks, although it could have later been put on a flathead of other years." - Mike, not me.
Those powder coated parts look terrific. |
thanks
Originally Posted by Mixer man
(Post 18407424)
Those powder coated parts look terrific. do you know if i can change the diver style dizzy to a newer type the one i have is shot, completely corroded cheers for your help i really appreciate it Stuart |
Originally Posted by aussie bl
(Post 18407476)
Do you know if i can change the diver style dizzy to a newer type the one i have is shot, completely corroded
cheers for your help i really appreciate it Stuart https://www.speedwaymotors.com/1932-...tor,11999.html |
(Post 18408122)
Speedway sells this one. I think there are others as well. There are also remans available, but personally, since I hate helmets I'd go electronic.
(Post 18408535)
thank you so much i do believe ill get one like that ill see if i can get it here first as 550 is a lot that's with exchange rate and postage but if i cant ill be using speedways one
