4 Attachment(s)
OEM Sway Bar install is complete.
Simple and straightforward design; no instructions provided, but none are needed. Attachment 287876 Attachment 287877 Attachment 287878 Attachment 287879 All for just over $100.00 |
Originally Posted by workingdan
(Post 17230896)
I didn't notice a difference.
Ordered F-250 Lariat CC gasser on April 10, 2017; received May 17, 2017.
What is the diameter of the OEM rear sway bar??? Am looking at Hellwig, too. Thank you. |
Deleted - information found
Does the bar come with the rubber bushings?
Originally Posted by JeepPuller
(Post 17231567)
Simple and straightforward design; no instructions provided, but none are needed. https://i.imgur.com/cRT1BGHl.jpg https://i.imgur.com/dmnPCkLl.jpg https://i.imgur.com/tcpVgmQl.jpg https://i.imgur.com/g1FaNM3l.jpg All for just over $100.00 |
Originally Posted by Anibal Medina
(Post 17253067)
FWIW I installed my Ford OEM bar this afternoon in about 45 minutes, and a good portion of that was looking for tools I had misplaced. 103 Nm for the bracket bolts and end link nuts, and 48 Nm for the bushing bolts on the axle. Use vice grips on the end link ends to keep the stud from twisting in the rubber mount. Easy.
I completed the OEM sway bar install tonight.
Some tips: Install the frame brackets first and torque them down. On the driver's frame bracket (the one near the fuel tank), have the end link inserted between the bracket and the frame before installing, because once the bracket is bolted to the frame, you can't get the end link in place through the gap (at least on my CC SB diesel). Once the frame brackets are in place, hand tighten the top nuts on the end links to get the end links positioned. With the end links in place, hang the bar from the lower bolt on the end links. Then bolt up the axle brackets. The flat of the bushing sits in the flat of the brackets; the curve of the bushing sits on the axle. Finally, come back and torque down the end link nuts and the axle brackets. Converting the numbers Habemus Quattro posted above: 75 ft-lb for the frame brackets and end link nuts, 35 ft-lb for the axle brackets. I don't have a service manual, so I'm not in a position to question the numbers that were posted, they sounded good enough for me. One caveat: I think the sway bar itself is directional, meaning I think there's a "right side up". In JeepPuller's pictures above, the sway bar hangs down right at the bottom level of the pumpkin or slightly below. This is the way mine is installed right now. On page 4 of this thread, CGA posted some pictures of a factory-supplied sway bar which looks like it sits a few inches above the bottom of the pumpkin. I think there's a slight angle on the bar, and you need to orient it "right side up" to get it to look like CGA's pictures. I'll probably pull mine off and reorient it tomorrow to confirm; I'm sure it works fine either way, but I'm not comfortable having the sway bar (which sits behind the axle) as the lowest point on the truck. |
A couple of other thoughts I just remembered:
I greased up the bushings at the bar contact points with a synthetic grease before installation. Just slide them back, grease up the bar, and return them to their mounting position. Also - I did not need vice grips to hold the end links while tightening the nuts. The bolts stayed in position just fine. |
I installed the big wig as well but by looking at pictures above of the factory bar, looks like I need to shorten my links to bring the bar ends up higher, I was wondering about that they look too low to me. Looks like they can hook on something.
Originally Posted by wb6anp
(Post 17353625)
Originally Posted by mooch91
(Post 17353473)
snipped
One caveat: I think the sway bar itself is directional, meaning I think there's a "right side up". In JeepPuller's pictures above, the sway bar hangs down right at the bottom level of the pumpkin or slightly below. This is the way mine is installed right now. On page 4 of this thread, CGA posted some pictures of a factory-supplied sway bar which looks like it sits a few inches above the bottom of the pumpkin. I think there's a slight angle on the bar, and you need to orient it "right side up" to get it to look like CGA's pictures. I'll probably pull mine off and reorient it tomorrow to confirm; I'm sure it works fine either way, but I'm not comfortable having the sway bar (which sits behind the axle) as the lowest point on the truck. Interesting observation... Anyone with a factory installed sway bar care to take a few shows from the rear and front of the axle? I'll see if my BIL can check out new trucks at his work, and pass on what I learn. |
(Post 17353984)
JeepPuller - I just took a look at your picture of the parts laid out on the ground. The bar itself seems to also have a shape that would match the contour of the rear diff cover. The way you have it laid out is opposite of the R&P bump-out on my cover, which is on the left-hand side when facing the axle from the rear. I didn't notice this on mine (but I may have just missed it). I'll drop it tonight and flip it over, and will take some more pictures if it makes a difference. |
(Post 17353987)
I look forward to seeing what you find out. |
4 Attachment(s)
Pulled my bar off tonight (much quicker than installation).
There is definitely a "direction" to the bar. See attached pictures. As I thought, the bar has a shape that looks like it follows the contour of the rear diff cover. I flipped mine over to better match the cover and the bar no longer hangs slightly below the rear diff. Brought it up a few inches. Again, not sure it would make a difference to the function of the bar, I just feel better knowing I put it this way. Attached some pictures, including a before and after (may be hard to tell the difference). |
