Originally Posted by blkout50
(Post 16782216)
720-01-01 EA21 BA82 7FEF, OCR trucks 726-03-01 0201 0000 34, OCR trucks 720-01-01 EA21 BA83 FF70, My truck 726-03-01 0201 0001 35, My truck My truck didn't like the 726-03-01 and would not accept those values from the OCR trucks. Here is what it did take; 726-03-01 0101 0000 33 So far no DTC's... 726-03-01 0101 0001 34 It did accept the numbers from the OCR truck (0201 0000) but it reset to 0101 0000 and changed me from a 4 door truck to 2 door (in BdyCM module) 0201 0001 is accepted but resets to 0101 0001 Mike, please see if your truck changed from 4 to 2 door. If so, this can be added to the spreadsheet. 726-03-01 xxxx xxx0 is 2 door 726-03-01 xxxx xxx1 is 4 door I could not tell what the difference between 0201 and 0101 was because after it wrote 0201 it would reset to 0101. Bob |
swarf-rat,
not sure about the mileage, but the dte can be tweaked by adjusting the fuel tank size, and tire size can be adjusted. Im doing an experiment with mine right now. miles to empty was 5. Fuel % on TP was 0.0% flashing. I put exactly 5 gallons in, i'm up to 12.5% now. I should be at 7.7%. (I have a Titan 65 gallon tank). I will be filling up tomorrow. I don't normally run this low, but figured to try this since I was. It will give me an idea of what the "safety factor" is. Keith |
Originally Posted by Trash Hauler
(Post 16783340)
My truck is
726-03-01 0101 0001 34 It did accept the numbers from the OCR truck (0201 0000) but it reset to 0101 0000 and changed me from a 4 door truck to 2 door (in BdyCM module) 0201 0001 is accepted but resets to 0101 0001 Mike, please see if your truck changed from 4 to 2 door. If so, this can be added to the spreadsheet. 726-03-01 xxxx xxx0 is 2 door 726-03-01 xxxx xxx1 is 4 door I could not tell what the difference between 0201 and 0101 was because after it wrote 0201 it would reset to 0101. Bob Just checked and mine changed to 2 door also. Nice observation, I will update the spreadsheet with your find. Mine is also "stuck" on 0101 and I am unable to get it back to 0201. One thing i just now noticed is that 2 door extended cab is also treated as a 4 door (xxx1). I am using a 2 door extended cab without OCR for AB file comparisons. That tripped me up when I first noticed 726-03-01 My DPF is still at 95% so I have not seen the any change in my DPF screen. Good news is that I no longer have a DTC. |
Did a bunch of playing around today with IDS and FORScan.
**Warning if you change IPC settings with IDS you will loose any saved trailer data info. How do I know ?:-X19 Working with blkout50 to find the OCR. Keith |
Originally Posted by ZooDad
(Post 16785590)
Busy day
So I got to playing around with IDS and FORScan yesterday.
I located and confirmed axle ratios and tire sizes. I have updated the spreadsheet with this info. HUGE shout out to F150Forum member Spart for his awesome WORK and developng his Tire Size Conversion Sheet. With this info you can custom set for your truck for the most accurate speed / ODO. No more settling for close enough. The guys over there have been very helpful helping us locate things in our trucks. I think the 17 guys would benefit the most as they most likely share more of the codes then we do. Still chasing down OCR. I located a reference using IDS that references Diesel Particulate Filter Regen Request. But I think it is only half of the equation. I have a couple inquiries out. I will keep you updated. Keith |
AWESOME find Keith!!
1 Attachment(s)
We haven't found the settings for the OCR... yet, but did find out how to turn on the Compass on the Info Center screen.
720-01-01 xxxx xxxx Exxx, DPF Screen, (Disable) 720-01-01 xxxx xxxx Fxxx, DPF Screen, (Enable) 720-01-01 xxxx xxxx 6xxx, DPF Screen, (Disable) / Compass, (Enable) 720-01-01 xxxx xxxx 7xxx, DPF Screen, (Enable) / Compass, (Enable) Mike Attachment 196068 |
Keith - uploaded my as built to your google. 2013 f250 Lariat, Crew cab, short bed, 6.7 diesel, 4x4, Nav, MFT, 5th wheel & gooseneck package, Bluejean Met., 20" wheels & tires, 3.55 e-lock.
I'm trying to fine a copy of my window sticker for you. |
(Post 16788798)
720-01-01 xxxx xxxx Exxx, DPF Screen, (Disable) 720-01-01 xxxx xxxx Fxxx, DPF Screen, (Enable) 720-01-01 xxxx xxxx 6xxx, DPF Screen, (Disable) / Compass, (Enable) 720-01-01 xxxx xxxx 7xxx, DPF Screen, (Enable) / Compass, (Enable) Mike I sent you a PM about a vendor,, CircuitBoardMedics, that have done some productivity screen updates. You might inquire with them about the OCR. |
Originally Posted by Just Strokin
(Post 16788943)
Great work Mike....I know some with the 2013 and up trucks will be happy with this.
I sent you a PM about a vendor,, CircuitBoardMedics, that have done some productivity screen updates. You might inquire with them about the OCR. Mike |
(Post 16788798)
720-01-01 xxxx xxxx Exxx, DPF Screen, (Disable) 720-01-01 xxxx xxxx Fxxx, DPF Screen, (Enable) 720-01-01 xxxx xxxx 6xxx, DPF Screen, (Disable) / Compass, (Enable) 720-01-01 xxxx xxxx 7xxx, DPF Screen, (Enable) / Compass, (Enable) Mike http://i272.photobucket.com/albums/j...psiwi4mwt1.jpg |
Originally Posted by 4df150
(Post 16788815)
I'm trying to fine a copy of my window sticker for you. Keith |
(Post 16789457)
Great find Mike. Thanks for the update.
1 Attachment(s)
(Post 16789459)
Thanks for the upload. I will grab the data and run etis.
Keith |
