After hitting 6 stores, as I walked to the checkout in Pepboys, I realized I had 2 bottles of RP 75W-140 and 2) 75W-90 :eek: they had them all in one slot.
I gave the oil pan ( on the 2000 ex) and the front diff cover the Por-15 treatment!
Degreased and power washed the engine bay today getting water in the power steering pump which lead to a power steering flush with merc 5.
Only things left now are new tires, trans flush, and pinion seal/diff fluid change. Then this X will be prime an good to go for the next 90K miles. |
Can someone post a pic of these late model differential covers please?
i washed mine up and worked on some of the scratches with rubbing compoud. my next step is to remove all the tar, clay bar it, compoud/buff the whole truck and then wax.
Originally Posted by slenser
(Post 9238126)
https://www.ford-trucks.com/forums/8...ial-cover.html |
Thanks howler, I was looking at CFR's website that has something similar in a polished aluminum. I may just go with them for slightly more.
Originally Posted by AlaskanEx
(Post 9238420)
I just went threw all this not long ago with my X. I have found that regular gas works great for removing tar off the plastic running boards and lower skirts. |
Originally Posted by Snowseeker
(Post 9239472)
Stewart |
i used to use some great stuff from 3M but i went to buy some yesterday and could not find any! kinda pissed me off. so i'm gonna stop by a autobody store today and get some.
Originally Posted by Stewart_H
(Post 9240118)
Diesel fuel actually works better because it's less harsh on plastic.
Stewart Yes the gas will dry out the plastic. After I got all my tar off I went back and oiled all the plastics with some plastic/trim conditioner. |
New tires came in! Went to buddies shop and mounted and balanced the tires myself. So far very happy with them!
put a new pass side door lock actuator in. now all of them work! woohoo!
I looked at mine sitting there as I took the dogs out to poo.
Routed the wiring to my new Ultragauge and flipped the armrest covers around this morning.
