Originally Posted by pig9r
(Post 20141386)
Looks like it. Straight off of the boat from China.
Thank you for creating this thread, I thought that area looked off but didn't think too much of it. I called my local dealer and they have both "filler" trim pieces in stock so I will pick them up this afternoon :-X22
Make sure you order the correct number of fasteners. I ordered (Fairway Ford) 2ea W712559-S900 & W708991-S439 expecting to receive 2ea packs of four (8 pieces of each part). Instead, I received these; two packages, clearly marked as packs of 4; cut open and only 2 pieces in each package. If I order more I'll get hit with another $12 shipping charge.
I have not installed them yet, so not sure exactly what I need. https://cimg8.ibsrv.net/gimg/www.for...2921cc05c2.jpg |
I’d read various reports of what was needed to install these. I emailed Fairway Ford and asked if the screw & clip part #’s were a 4-pk or single piece. They responded “single piece”. So seems they are doing like you say, opening the 4-pk bag and selling the parts individually.
I ordered all the parts for my install from FordParts.com. see my post #19 in the thread below for pics & details of what is needed per the Ford parts diagram https://www.ford-trucks.com/forums/1...r-liner-2.html |
I’ll just post it here too……
So I found when I went to order these that the parts diagram shows each liner using 2 push pins (come with liner) and 2 screws (and clips). The screws and clips come in a 4-pack. Below is what I ordered. Just installed them per the parts diagram. https://cimg1.ibsrv.net/gimg/www.for...af645f25c.jpeg https://cimg3.ibsrv.net/gimg/www.for...b3f67aee0.jpeg And here’s a pic on my truck. https://cimg8.ibsrv.net/gimg/www.for...42de893fc.jpeg |
Originally Posted by scottz99
(Post 20397172)
Thanks for the help; I'm sure I'll find enough stuff in the shop to complete the install.
Delete, bad math haha
I keep going back and forth whether these will be better or worse for winter corrosion,
Originally Posted by ToMang07
(Post 20446115)
Installed the fender liner extensions last weekend after installing the front wheel well liners. I bought the clips and screws to use but ended up just using some of those plastic retainer pins that came with my trim removal tool. So far so good. If they decide not to hold I'll switch over to the clips and screws for those two holes. Cheap and easy install.
bringing this back up.
do these fit on the '23-up trucks? thanks |
I have the plastic wheel well liners and I like the idea of these in addition to what I have. Wish I would have seen them a few years ago, but I am going to order them now.
has nobody done this on a '23 truck? are the fenders/bumper any different in that area?
Originally Posted by kylant
(Post 21112900)
On the 17 you can see the two mounting points circled in red. Their are no provisions on my 24 for those mounting points. https://cimg6.ibsrv.net/gimg/www.for...87564a1ca1.jpg Image from my 24. No mounting points on the backside of the bumper. https://cimg8.ibsrv.net/gimg/www.for...3738589c5f.jpg |
