You should see 18 psi on a WOT run unless you are running a programmer or tuner.
Did you look at the wastgate in the turbo when you had it apart? Moved freely without binding?
Originally Posted by Nicmike
(Post 13418967)
What type of boost gauge are you using?
(Post 13418978)
Do you feel it is running sluggish? Does it feel like it is only getting partial power and boost? I think there is a problem with your Edge product after all you have done to your truck.
(Post 13418984)
Well, I have my fingers crossed that tomorrow you hit 18-20 psi! You should hit 24-25 in your race tune.
(Post 13418999)
I still believe you have a big boost leak.... When one of my couplers were only half on because some idiot who owned the truck before me didn't put it on right I was only able to hit 15 pounds of boost any of my tunes.
You never specified how you went about checking for boost leaks. You did say that the system did hold pressure... Which I then said that it won't hold pressure, it will bleed off. I believe you may need to go back and start at square one all over again and tripple check to make sure your not missing something. |
Originally Posted by JOHN2001
(Post 13420499)
Originally Posted by 99F350bigorange
(Post 13420553)
I will definitely go back and recheck for boost leaks this weekend. I used a website I found where someone had showed step by step how to do the leak test and mine seemed to do the same as theirs. Ill try and find it again and paste the link on here.
(Post 13420641)
There are a lot of threads on how to make a boost leak Decetor and check. I'm curious to know the method you used.
(Post 13420788)
Took the air filter off and put a piece of PVC with a Schrader valve tapped in it in the boot and pressured it up inbetween 15-20 lbs and listened ands sprayed Windex for bubbles.
Originally Posted by timmyboy76
(Post 13420842)
lets hope you didnt do a gomer move like me...and install the BLT before the ccv vent...lol
