Got any more info on the motor home rail chassis PS pump. Will it fasten directly to the existing Super Duty PS pump bracket? Does it use a better high pressure PS hose connection to the pump?
I agree the PS pumps on the Super Duty are a piece of junk. Besides the funky O-ring sealed plastic pump housing, the high pressure hose connection to the pump is a joke. The high pressure power steering hose blows free of the PS pump due to lousy design. |
So basically the bolt was stuck in the monifold and not the threads themselves? I was told back when I first got my truck to check for leaks and I remember being able to get a lil bit on all the bolts. But that was with a long 3/8 ratchet, I didn't know what a torque wrench was back then! Lol
Guess what I was getting at was we don't have that corrosion issue round here unless you get down on the gulf!
Originally Posted by bulla
(Post 10270499)
The bolts stick in the manifolds because the threads create a space in the smooth bore of the manifold. RUST expands steel 4x and LOCKS them in place. The torque on bolts to heads is only 38ft lbs IIRC - and no 'space' for rust - so they seem to come out pretty easily. I am quite certain you went ahead and replaced all the bolts, but since ya didn't mention it...
Rust sucks! I think coating the manifolds will help mitigate this problem and wonder if it would be worth the effort to coat the part of the bolt that goes thru manifold for good measure. I lathered mine up with high-temp anti-sieze, but know it won't last forever in that environment. I'd say you need some resurfacing - but we can only hope its the manifolds that are out of spec... Don't use gaskets unless you like this job, since they will eventually 'wear out' for the same reason the donuts in stock up-pipes fail. Metal-to-metal should last indefinitely. Btw, I'll be passing thru in a couple weeks - hoping to hook up with y'all on the way by! Dunno if you've seen the new Toy Hauler TT behind the Excursion yet, but we sure do like it! :-drink Setting up the CF, etc in the garage for the ultimate on-the-road filtration system as well as extra clean WVO storage and pump/hose for easy refueling in-route! :-X04 |
Please tell is more about this motor home PS pump
Oh yeah, are you using Turbo X coating?? Or some other product? :-huh
I have an extra set of manifolds I'm gonna blast and coat. Now that you've got some practice, maybe I'll just drop the X off at your place and pick it up when yer done? }>:-X04 It really sux ya live so far away these days, I'd have been there for you if I could....... :-X15 |
Jason, call when you're in the area (my txt is hit or miss)... I've amassed some new garage toys since your last visit. }>
Ok, I'll do more research for F53 chassis power steering pump. Nothing concrete right now EXCEPT it doesn't have the d&^% O-ring mounting/seal configuration. More to follow. |
So, I'm winning... here is what the doctor ordered to remove the rusted bolt on the passenger side manifold.
That's a 20-Ton press applying about 18, with regular PB Blaster shots. Didn't phase it. <table style="width:auto;"><tbody><tr><td>https://lh4.googleusercontent.com/_-...8/IMG_0263.JPG</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Exhaust Manifolds</td></tr></tbody></table> Maybe a relief hole drilled into the bolt will do it. <table style="width:auto;"><tbody><tr><td>https://lh3.googleusercontent.com/_-...8/IMG_0268.JPG</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Exhaust Manifolds</td></tr></tbody></table> Nope, still couldn't press it out. Ok I'll redeploy the blue wrench, along with a buddy. <table style="width:auto;"><tbody><tr><td>https://lh6.googleusercontent.com/_-...8/IMG_0287.JPG</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Exhaust Manifolds</td></tr></tbody></table> Well with ~20min of heat, burning off the rust, it still wouldn't budge. Last trick, poured some liquid CO2 down the relief hole in the bolt... THEN it pressed out! :-jammin <table style="width:auto;"><tbody><tr><td>https://lh4.googleusercontent.com/_-...8/IMG_0289.JPG</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Exhaust Manifolds</td></tr></tbody></table> My album, https://picasaweb.google.com/CasperC...eat=directlink, also has pics of how bad the rust really was on this manifold. Much worse than the D/S for some reason. Had to deploy the needle scaler prior to blasting, but the finished product is good.:-X06 Just an update, till paint, weather here is BAD. |
Holy crap! :-hair
Uh, where do ya get liquid CO2?? :-huh |
:-drink
(Post 10291418)
Holy crap! :-hair
:-X03:-X03 Ok, I'll let you guys in on my secret... How about a can of dust off, up-side DOWN }>
I was thinking that but didn't know if you had a bigger supply of it or something. So are you having the manifolds re surfaced? And are you using a gasket?
Originally Posted by CPUNeck
(Post 10296016)
Yep, necessity is the mother of invention. You should've seen my nephew's face, he learned a lot :-X04. We both were concerned the press was going to torpedo my manifold across the shop.
I'm going to use a gasket... it's an experiment, as alot of what I'm doing is, until I get my up-pipes. It will probably about a year before I install them. Testing: Grill paint on the up-pipes and down pipe. Techline "Black Satin" header coating (manifolds, compressor housing on turbo) Permatex® Ceramic Extreme Brake Parts Lubricant (as rust inhibitor for bolt shoulders at manifold, and all exhaust connections) Caliper paint (5-way plenum, and CAC tubes) We'll see how they all perform. :-X06 |
