I can not get the code to go away when reprogramming tire size for my tcm 23 f450 37's and level kit
Originally Posted by Robbs0385
(Post 21118134)
Tire Size Calculator ZooDad |
Thanks!!
Originally Posted by ZooDad
(Post 21117623)
Thank @Peej11 , @ATC Crazy and @kylant for there data lines.
The Super Duty change is (APIM) 7D0-02-02 xxx2 xxxx xx-- While you are there might as well make the change to remove the black box from the camera view (add 1, so 3)(Sync version must be 23151 rev 902 or higher) When you make the change post up a photo Spreadsheet updated ZooDad If I want it to be 5 blinks would I add 2, so 4? Not sure what the "black box" is... Can you elaborate or give me a link to go catch myself up? Thanks again!! I'll try to get some pics uploaded tomorrow on my introduction post. What a great community this seems to be! |
ok. just did my first changes in this new truck. have used forscan before on previous trucks.
quick question, first change was to lower the tpms thresholds. when i inputed the values i wanted, 50/45, the rear changed other values in the block and then a warning came up about the checksum value not correct. i continued, everything seemed to program correctly. when i looked at the tpms values in plain english, the values i wanted are correct. is it normal for some values to change when others are inputed and for the checksum warning to pop up? also, the values i posted above from the as built website, match what is actually in my truck |
(Post 21118164)
I tried everything. I relearned the tcm 5 times and the code persisted. It did work and would drive but I had to revert to stock to get the Tom code to clear. |
(Post 21118334)
Originally Posted by stroke250
(Post 21118356)
If all you have is the P160 with no lights, it runs fine, and speedo is where you want it, I would run it.
(Post 21118390)
it is only that one code. But it throws light on the dash for service 4wd and no pre collision.
(Post 21118458)
Have you done all the relearns? TCM, PCM, and AWD?
(Post 21118460)
I did the pcm and the Tcm. I didn’t understand the awd needs to be relearned also. Does it read the same as the other two?
Would be happy to test stuff as well. 2023 F350 6.7 HO Tremor XLT.
Would love to be able to keep the amber turn signals on as DRLS. Thank you for your awesome work @ZooDad ! |
Originally Posted by kylant
(Post 21118281)
quick question, first change was to lower the tpms thresholds. when i inputed the values i wanted, 50/45, the rear changed other values in the block and then a warning came up about the checksum value not correct. i continued, everything seemed to program correctly. when i looked at the tpms values in plain english, the values i wanted are correct. is it normal for some values to change when others are inputed and for the checksum warning to pop up? also, the values i posted above from the as built website, match what is actually in my truck ZooDad |
(Post 21118134)
(Post 21118164)
(Post 21118334)
(Post 21118390)
(Post 21118460)
https://cimg1.ibsrv.net/gimg/www.for...acaee2b114.jpg ZooDad |
Turn Signal Flash
OK,
So thanks to the help of @wabba we have figured out the AsBuilt value changes for Turn Signal Flash. The spreadsheet has been updated. ZooDad |
(Post 21118679)
@kylant Yes when changing values in AsBuilt the last two (2) values will change. Those are the checksum to the line to make sure it is correct.
ZooDad my values for 60/65 pressures were: 726-10-01 0201 003C 41BE changed to 50/45: 0201 0032 2DA0 |
