So we got everything reinstalled around 3am... took it for a test run to get some new numbers but with my foot on the floor; the speedo reading 60mph my boost gauge was only telling me 9psi.... Diehard and I plan to get back at it tomorrow afternoon and we also plan to get our final numbers posted by the end of the day. We think we have a solution for the boost leak, just a simple reposition of the spyder.
Quite the disappointing event to end the night... 5 hours of work to end like that... Got the compressor housing back on and bolted the 1.0 housing on. http://i1345.photobucket.com/albums/...ps4762591b.jpg http://i1345.photobucket.com/albums/...ps93e6f481.jpg I do believe this picture has the outlet back on the backside. So the turbo is now back together. http://i1345.photobucket.com/albums/...ps09e98c0b.jpg Got the turbo positioned and reinstalled. http://i1345.photobucket.com/albums/...pse6d091eb.jpg Everything is back on and she's ready to go! http://i1345.photobucket.com/albums/...ps131dac36.jpg |
Originally Posted by DHamSTER
(Post 13745798)
Diehard and I read that at the same time, looked at each other, turned and looked at the IC pipe at the same time with a confused look on our face, then looked back at each other trying to figure out what the H311 you were talking about, looked back at the IC pipe and we decided that we think its manufactured that way, if not then somebody put a huge dent in to make it fit.
Originally Posted by BigAlsPSD
(Post 13746122)
It is manufactured that way to provide clearance around the power steering pump.
Looking good.
Dylan thanks for the photos I am sorry it going to take alittle more work to get it dialed in. But looking good! :-X22 It is hard to tell by your photo but the clamp on the syder to turbo doesn't look right. Now I am sure you were planning on doing this anyway but make sure all them new fancy lower syder & plenum clamps are loose until you have the syder to turbo sealed. Check the oring for damage.
I can't wait to hear how this set up works out for you. Because I have a feeling you should be the same results as the guys running a ported compressor housing but better boost #'s. But what I want to know about is do you get any surge when towing down the highway. Do you tow? If so please post up after towing with this combo. There is one more thing that I think would help compliment this set up is a Turbo Master w.g. actuator. I run one and I am very happy with it. But mind you the stock w.g. actuator is actually way more refined in doing the job. But T.M actuator gives you way more adjustabilty. So it is somewhere in between a stock w.g. actuator and a non waste gated housing. Just something to think about. |
Originally Posted by BadDogKuzz
(Post 13746656)
I can't wait to hear how this set up works out for you. Because I have a feeling you should be the same results as the guys running a ported compressor housing but better boost #'s. But what I want to know about is do you get any surge when towing down the highway. Do you tow? If so please post up after towing with this combo. There is one more thing that I think would help compliment this set up is a Turbo Master w.g. actuator. I run one and I am very happy with it. But mind you the stock w.g. actuator is actually way more refined in doing the job. But T.M actuator gives you way more adjustabilty. So it is somewhere in between a stock w.g. actuator and a non waste gated housing. Just something to think about. Diehard got a ported housing with his Beans chip back January and in stock tune the ported really has no performance increase except for the elimination of surge. I actually plan on getting the Big Head Wastegate. I believe it's almost the same actuator as the one you recommended. |
(Post 13746678)
Thanks for the advice and pointers! Diehard is actually the one doing the new plenums, when I posted the first pictures of all the new toys I listed who has what.
This might help to actually see the difference. This is my E99 turbo with 1.0 housing, WW and TM.
https://www.ford-trucks.com/forums/p...ictureid=95457 |
(Post 13746781)
(Post 13746814)
What is the difference between the big head and the turbo master?
Dude put down the bong and reread... please http://www.420magazine.com/forums/im...ies/smoke2.gif |
(Post 13746891)
Dylan you are killing me here. :-roll I explained the best I could 2 post ago and I think if you compare the photo of your turbo and the photo of mine you should see the differents.
Dude put down the bong and reread... please http://www.420magazine.com/forums/im...ies/smoke2.gif I missed your post comparing the two cause you post the picture... I was thinking of looking into that wastegate until that little comment so I'm gonna stick with the Big Head. Thanks!! |
Last night when we tried to put the downpipe clamp back on we noticed that the nut would slide back and forth on the bolt, slightly, so you couldn't torque it down tight. SO this morning we got up and solved the spyder issue from last night and of course had to take that clamp off again to put the new exhaust on.
This is what we found and some minor fab work by Diehard (Because we couldn't find a new nut to fit the stock bolt on the clamp so we found a new nut and bolt to take its place): http://i1345.photobucket.com/albums/...ps414ac258.jpg |
(Post 13746915)
Put down the bong and reread? You gotta be kidding me. Im thinkin' you should put down the bong Mr. 420magazine.com.....
I missed your post comparing the two cause you post the picture... I was thinking of looking into that wastegate until that little comment so I'm gonna stick with the Big Head. Thanks!! And for what it worth I am glad you got your problems solved. Or should I say I am glad that Diehard fixed it. |
HAHA either stupid or stoned? Come on man.... How about neither? How about I just missed your comment.... Your little stoned joke was too far. It's not the fact I can't take a joke, it's the fact that it's over the internet....
I'll let Diehard know you applauded his fix.... |
Don't mind me...just passing through...watching the latest project thread...enjoying the humor and friendly ribbing we do to each other....giving reps to Ed for showing patience to the new guy as he's inducted into the Brotherhood family....thinking maybe more smilies should be used in posts.....nothing to see here.....
Stewart |
