Not sure if its mentioned in the write up this is also a good time to clean ur exhaust back pressure tube and inspect it for holes.
OK, got the parts. Got the fuel bowl off.
How in Hades do I get the HPOP off? I found 1 10mm bolt on the upper passenger side and removed that but the HPOP is still on tight. Please help me, soon. |
There's a little football shaped plate on the front side of the HPOP reservoir (up by the radiator fan). There's a drive gear bolt under that cover that you need to remove.
I think there's also a bolt on the back side near the IPR. Did you get that one? |
Originally Posted by F350-6
(Post 9216484)
I think there's also a bolt on the back side near the IPR. Did you get that one? Thanks |
OK. got all the bolts I could find out. I cannot get the HPOP to break loose. ????
Did you remove both 10mm bolts? Did you remove the 18mm bolt holding the gear on the front of the pump(behind the little front cover held with two 8mm bolts)?
Originally Posted by TerminatorEng.
(Post 9216958)
Where do I refill the HPOP? |
Originally Posted by PJ-Hunter
(Post 9217002)
yep. That other bolt on the left side was a PITA. Now I gotta try and refill the pump but I have to wait 24 hours for the Loctite to cure. So tomorrow at 10:30pm I'll fill it and test it.
Thanks a bunch. You guys :-headbang
So, I know that the instructions say that the Loctite has to cure 24 hours before putting oil back in the HPOP. Is that gospel or is there a more acceptable time frame.
Cuz, this will put me at home all weekend and that means house work. YUCK! |
(Post 9217618)
Cuz, this will put me at home all weekend and that means house work. YUCK! If it were me, I'd give it the 24 hours. |
Will do. Just wondering. Just gonna go finish torquing bolts and bolt a couple other things up so I don't lose tiny parts
Fudge!!! I need the HP fuel line o-rings and the dang dealer closed early and won't be open till Monday. The work ethic of some, I swear.
Wish there was a way for me to get them today or tomorrow.:-X09 |
(Post 9217618)
Originally Posted by DieselOrings
(Post 9218127)
The 24hrs is from LocTite. VERY important, especially on the non-serviceable plug.
Too bad you are so far from my location. |
If they go out today, your PO will have them first thing in the am on Monday.
(Post 9218166)
Yes, they should be in your PO box by the time the PO opens Monday.
(Post 9220345)
