Originally Posted by kylant
(Post 21114130)
can you post where to find the tire pressure converted to hex values?
I can't seem to find them. thank you ZooDad |
TPMS thresholds are easy with plain english
any tried to disable the door ajar chimes?
it's super annoying also enabling heated seats/wheel on the sync screen, does that put them at the bottom with the audio, settings, carplay, etc... tabs? what is the value? line 22 of the spreadsheet, it is blank |
Thank you so much! I'll probably try to make some changes again tonight and see if I can figure out what I was doing wrong last attempt.
(Post 21115738)
it's super annoying also enabling heated seats/wheel on the sync screen, does that put them at the bottom with the audio, settings, carplay, etc... tabs? what is the value? line 22 of the spreadsheet, it is blank I usually only use FORScan every couple of years when getting a new truck. I make a few changes and then forget it. So renewing the 2 month license every couple of years has worked so far. |
Regarding climate bar
if a couple of people can post the entire line for APIM 7D0-02-02 I will confirm the correct value ZooDad |
Originally Posted by ZooDad
(Post 21116700)
if a couple of people can post the entire line for APIM 7D0-02-02 I will confirm the correct value ZooDad Lariat Ultimate |
Anyone know anything about what may need to be done in ForScan if i replace my 2024 Lariat Reflector LED headlamps with the Projector Style that come on the Platinum trims?
I am trying to figure out how to get the Autoleveling feature to work, and possibly if i can enable to the lights to adjust based on steering input as well. |
(Post 21116700)
if a couple of people can post the entire line for APIM 7D0-02-02 I will confirm the correct value ZooDad My original As-Built line is: 0210 00DC 04CD |
Has anyone done the increased number of blinks when changing lanes from 3 up to 5 or 6? I did that on my '18 F150 King Ranch, but just got a '24 F250 Lariat Ultimate... Lot of the things I had to use forscan to change on my F150 is available in the set up options of this new ride (such as the auto fold mirrors and digital temp displays for transmission and engine). Sure got used to those "extra blinks"... :-X22
(Post 21116700)
if a couple of people can post the entire line for APIM 7D0-02-02 I will confirm the correct value ZooDad 7D0-02-02 4210 00DC 040D '24 F250, 7.3, lariat ultimate |
Thank @Peej11 , @ATC Crazy and @kylant for there data lines.
The Super Duty change is (APIM) 7D0-02-02 xxx2 xxxx xx-- While you are there might as well make the change to remove the black box from the camera view (add 1, so 3)(Sync version must be 23151 rev 902 or higher) When you make the change post up a photo Spreadsheet updated ZooDad |
Originally Posted by SaltwaterSlick
(Post 21117093)
(Post 21117093)
Originally Posted by wabba
(Post 21117650)
Believe this is in plain english also, just take a look around, set mine to 4 instead of 3.
