I've noticed searching on the forum that some people use either the moog 824 or the 844, and what do you guys mean about bushings?
Originally Posted by greentruck72
(Post 18313146)
If you lift the suspension on these trucks in the front, the suspension swings in a arc, and the front tires will be tucked in at the bottom. There is only a limited amount of adjustment in the eccentric bushing, lift it too far and you can't get it back in alignment. That is why they have lift kits with drop brackets to bring everything down together and try to keep the wheel straight. |
