When they flushed my system, they used pre-diluted...
If you are really worried about it afterwards, get the test kit and it will tell you whether you are within spec or not. Make sure you get the RIGHT TEST KIT too... |
I'm not too worried about it. Right now, I'm more concerned with getting the right stuff in there and I've got all the numbers for the test kits if I need them. Thanks for all of the help.
I think you will be fine with whatever is left. It will be very little.
Where do you live?
Do you tow a lot? Your climate and duty cycle would either concern me or relax. I mean, if you live in the south you need not have the max freeze protection so your water content could be a little high and you'd be fine. If you work the motor hard, then I'd take steps to measure what comes out and try to get it as right as possible. The info I'm throwing out here adds nothing to the good help you've already gotten, I'm just trying to lower your stress level if I can.... |
