Thanks Frank for posting the chart. It Helps !! Because I have been running 800:1 to 600:1 with Blue Marble. I use it in all my 2 strokes and I love it. Smells like french fries when I use it in my outboard with ValveTech marine fuel. I use it in the truck since I have it laying around and didn't know how much to use. But to run it at 200:1 it will cost to much. Blue Marble® -- High Performance 2-Cycle Oil | Products | High Performance 2-Cycle Oil
So, I think I'll go to Wally world and buy a gallon of the cheap stuff. In the winter I run XDP Polar. |
two-stoke oil plus Diesel Kleen
I started using 2-cycle Walmart oil at 1 ounce per gallon as soon as I got my new-to-me 7.3l. It made a significant difference in engine noise.
When I combine that with Diesel Kleen I swear I barely recognize this truck. It is so much damn quieter, I just cant get over it! I am tempted to try some Rotella full synthetic engine oil next....but I am afraid I might just like the effect too much. Carrying around and adding the additives is kind of annoying...I use a funnel with measurements and an integral valve so I can measure and then dump what ever amount I need into the tank....first 2-stroke oil then Diesel Kleen to wash down the oil out of the funnel. Then I put the funnel in a sealable plastic baggy. Anyone have a better method? |
Originally Posted by Lex2002
(Post 11346716)
I havent ever read up or studied about fuel additives. ever since ive owned my 02 7.3 i have put that lucas injector cleaner in it. Is this good or bad. what would be better to use??????
Here is the graduate funnel I use with a valve in it. Hopkins FloTool 10704 Spill Saver Measu-Funnel. Works nicely for measuring and adding 2 stroke or diesel kleen. Just be careful with the little black closure thingamabob at the end...it can come off into your fuel tank...better to remove it before using and then put it back on to keep from dripping after your done.
Amazon.com: Hopkins FloTool 10704 Spill Saver Measu-Funnel: Automotive Now...if it had a lid...it would be perfect. |
Originally Posted by honeydew
(Post 11346851)
You can premix your blend and get some good containers for it. Use nail polish to increment the outside of the container for a qty reference, PS won't dissolve the nail polish. This link has good containers for additive, look at the 32 oz. barrier-lined (for odor): KAUTEX UN-APPROVED AGROCHEMICAL LEAK PROOF BOTTLES HDPE – Freund Container
Thats a good idea. Or perhaps when I finish up the large Stabilfuel bottle I can use that...it allows you to measure and pour in the same bottle. Then again it doesnt really hold much. |
