The common issue for that is the upper hinge pin wears out so the door sags down about 1/16'' of an inch when you open it. Then when you shut it the door striker lifts back up on it and creates a rubbing motion and wears through the paint. Lots of our trucks at work have done this and this seems to be the common fix. We simply loosen the hinges on the body and move the top hinge towards the front of the truck a tad then the bottom hinge normally stays in the same spot or if it needs to be moved it gets pushed to the back of the truck. Then we lub the weather stripping with dow 511 silicone or any o-ring lube will work. Open the door and lift up on the bottom corner and see if it moves.
Originally Posted by ford390gashog
(Post 10441321)
This truck also has only 46k on it so i dont think the doors have been opened too much |
Fluid film needs to be reapplied every few months or so. Like Kmonty said some people are just lazy and would rather just do nothing
Originally Posted by bigblue61
(Post 10441338)
Its sorta golden
I'm thinking its for more underneath It sprays on like wd40 but stays in a thick goopy application. Its like jello oil |
I would try applying some of the clear 3M protective film on the areas of the door that are rubbing. It should last for years. Amazon.com: 3M 84904 ScotchgardTM Paint Protection Film, Strip, 4 in x 84 in: Automotive This is the same film they use for chip shield on the rockers and fenders.
Is that rust on the rubber weather stripping if it is dirt/dust and algae clean it off and repaint the door and keep it waxed and the weather stripping clean and lubricated with silicone. If it were my truck I would pull the stripping and replace it then keep some silicone on the rubber to keep the crap from sticking to it.
Good luck Scott |
It looks golden but if you wipe it off it will leave a clear layer of product...Its very hard once something is coated in fluid film to completely get rid of it
I have always found having a Winter SD and Summer SD is the best way to handle this type of an issue. After 3 years the Summer SD becomes the Winter SD and something new and shiny replaces the Summer SD
I have the same issue OP. I am going to take advantage of the door hinge advice mentioned earlier. I too simply use Fluid Film and silicone grease on the seal.
Also, remove your lower door seals as you will find they simply collect crap and rot out the bottom of your doors. |
my 04 did this under warranty and the dealer wanted to paint the entire doors but i said no. the reason they rub is because ext cabs don't have a fixed pillar in the middle of the cab and ever pot hole bump or divot in the road or any flex in the frame suspension makes the cab flex side to side making the doors rub back and forth causing the rubber to rub the paint off the doors. Go look at ANY regular cab or crew cab super duty truck? OK did you look and what did you see? no rust, no paint missing right its because the cab doesn't flex making the doors rub against everything. I LOVE my truck but i will NEVER buy another ext cab as long as i live!
Originally Posted by SuperDutyScaler
(Post 10444071)
yea like i said i love my truck wish i had a V10 though but i hate the ext cab. ill never buy another one unless its a 97 or older ford that didnt open the back door. ever time i go hunting or mild off roading i can hear the doors creaking and moving, and if you park flex out the dorrs are hard to open because of the flex. my brothers 06 f-150 ext cab 4x4 does it my friends 02 f-250 does it and both of my cousins chevys do it too, just one of the side effects of ext cab fever i suppose
Originally Posted by dbc001
(Post 10442107)
(Post 10444379)
