Originally Posted by SteveBricks
(Post 12681636)
that's some funny stuff right there:-X22 |
Originally Posted by f-trucker88
(Post 12681642)
what ya pulling the intake for charlie?
Originally Posted by dustybumpers
(Post 12681640)
Yup. Off I go. Hopefully replacing plenum and intake gaskets work.
If not, I still have the 5.0 that came out of my fox body, lol pics not needed Steve took care of it:-X0A6 |
a flat spot?
Originally Posted by jr32560
(Post 12681669)
not a fun job
(Post 12681664)
There's a flat spot in the throttle. I have a suspicion of intake leak, but can't really tell. I also have a leaking valve cover, so Might as well seal it up. If real inspired, I may even re-seal the livter cover, it's leaking pretty good too.
(Post 12681678)
Mine were going to be a different view........:-missingt:-missingt:-missingt
(Post 12681676)
a flat spot?
(Post 12681679)
it's a 6 cylinder? 4.9?
had codes, and made repairs Map sensor idle control solinoid 02 sensor tuned it up, cap rotor, plugs wires replaced tfi repaired vacuum leaks replaced vacuum reserve can Egr valve and sensor |
Morning world.... looks busy out there today in MD.
Ummm, I SHOULD go out and remove the Xmas stuff..... |
Originally Posted by BPofMD
(Post 12681695)
Ummm, I SHOULD go out and remove the Xmas stuff. In my speedo.... |
I'd have to put on my fake black mustache to wear that!
(Post 12681209)
they actually expect you to work??
what kinda job is that }>
(Post 12681221)
Not a chance.
Don't worry Joonyah, I know you didn't do it :D
(Post 12681239)
Mornin' Steve!!!!!
See Pat, Now there is TRUE dedication for FTE. The man jumps out of bed, and on line at the snap of a finger!!!!
(Post 12681280)
Mornin Gig.
Thank Jr for fixing Md this morning. Pat broke it.
(Post 12681636)
(Post 12681691)
Yeah, falls on it's nose when ever you touch the throttle. Sucks to drive, because it's a clutch
4.9 had codes, and made repairs Map sensor idle control solinoid 02 sensor tuned it up, cap rotor, plugs wires replaced tfi repaired vacuum leaks replaced vacuum reserve can Egr valve and sensor drove me nutz till I found it--pressure was over 100lbs-might be the regulator? |
(Post 12681716)
Then again, she might NOT!
