08-10 XL headlights
The ugly black ones. Please come get them
I have a stock turbo wheel off my 02 7.3 truck and 2 EBPV off my 02 7.3 F350 and X and 2 stock intake boxes from both my 02 F350 and X. you just pay shipping.
looking for factory 2" lift blocks
I am looking for a set of factory rear 2" lift blocks. The ones with the taper and bump stops built in.
I have a 99 F250 SD super cab with shortbed 4x4. It has the factory 4" lift blocks that I would be willing to trade for the 2". If anyone has a set they would like to either trade or donate :-) I would like the hardware as well (ubolts). Thanks |
Looking for a pair of OEM headlights that'll fit a 2000 F250SD, the clear type if possible. Previous owner had some bad smoked lights I need to replace. Please PM me if you can help.
Thanks. |
I Have a IDM off a late 99 f-350, used but works great.
RDMobile May Have to go home and look I may have 2" blocks and the U-bolts, will let you know.
i Just replaced my mirrors on my late model 99 superduty, the connectors in the door were round. just letting you know
The plastic piece of my passenger side tow mirror on my 99 F350 has been cracked since I got it. I was tempted to upgrade to 08+ but I'm awfully cheap. Are yours tow mirrors?
Torqshift trans pan - free
I have a used but as good as new trans pan for up to '07s with Torqshifts. Always lived in CA and never seen salt, etc. It's free, but you have to pay whatever shipping is via USPS to you (I'll box it up :)). Oh yeah, it'll have the magnetic drain plug/washer too...
PM me if interested... |
Up for grabs is a (mostly) hollowed out Cat for a 6.0 Diesel, off my 2005, it has the studs and nuts. Never cut open/apart (Completely in-tact), just slips in and bolts down. You just pay shipping.
I just scrapped the rest of the system and only got $4 (and I thought steel was supposed to be expensive...)... eehhhhhh, At least it got rid of it. If I don't get any takers in the next couple of weeks I'm just gonna chop it up and chuck it piece by piece to get it out of my garage, Just so you guys know this is a limited time thing. |
Originally Posted by Retreever
(Post 12354911)
I travel a lot with my (2) old dogs (14 yr old male and 11 yr old female) Labs. I want to swap out the existing rear bench seat for one that folds flat so they can be more comfortable when travelling.
Thanks, Retreever The only "permanent" connection are a couple of small L brackets holding the divider to the vertical support. The divider butts up at the back to the rise in the floorboard for the rear seat. The plywood platform just rests on the front support (and the seat), but it is rock steady. My 85-pound boy jumps in and it doesn't even move. The platform can then be taken out in a second and stored behind the seat if I want to carry passengers. They would have a little less space for their feet since the front support blocks them from extending their feet up under the front seat. Advantages: low cost - prolly spent less than $20 for the plywood and brackets. Nice storage area under the platform on the floorboard, even longer items fit in over the half-high divider. The rear seat provides a nice cushioned backrest instead of the bare metal cab. Can also fold the front bench forward to access a small area in front of the vertical support. The result is a bigger platform, I assume, than a folded-over seat -- my big dog can sleep on his side with his legs outstretched. The platform sits lower than a folded-over seat so my boy has more headroom. Disadvantages: That might be a high jump for your older dogs (my guy is only 4), and the platform prevents the dog from jumping into the floorboard first, then up. I figure that once my guy gets older, I'll just stow a footstool that I can throw on the ground to boost him up. |
even though dan is offering the same thing I will "list" mine too, Trans Pan from my 05 with plug, Magnet, washer, and reusable gasket, Free to whoever wants it, you just pay shipping.
on another note, I still have that cat but I don't know how much longer, I'm thinking of trying to clear up the garage a little bit soon. |
Originally Posted by dfoxengr
(Post 14499118)
Thanks. |
Figured I'd post up the flat cargo deck thing that folds out from under the rear bench seat of my 2005 F350, only the folding platform thing, I am still using the seat and it's uprights.
Like usual; FREE, You pay shipping. |
Anyone have the center caps off a 2005 dually fx4 kingranch? I seem to have lost one of my rear ones somewhere between home in Pasco fl and my final destination of jacksonville nc, no idea where just noticed it when I got to my destination. I'd be willing to get the whole set (if anyone has them) if you don't want to break up the set, one of my fronts have a nick anyway.
