I'm in the same boat as Don...
Due to a loss of sub contract, I need to sell off some stuff. '93 Ranger. 4L, 4X4, auto, 176K, XLT. AC. Most items have been repaired, or replaced. All new fluids. Engine and tranny work flawlessly. A couple of spots of surface rust. Dents and dings. It was a work truck, till I got my diesel. It needs to pass inspection, a driverside rear frame cab mount, and either a patch or replace pass side front leaf spring hanger. (hooray for undercoating.) No other frame, body or rust issues. Many many new parts. 2 sets of tires/rims. Moonvisor. $1200.oo '92 F-150 XL I-6 5-speed. This truck looks very good inside and out. (for its age/mileage) 196K. I rebuilt/replaced/renewed just about everything on this truck. Rebuilt the shifter. New clutch, slave cyl, pedal bushings, rebuilt injectors, new 4 core rad, heater core, hoses, wires, plugs, iac valve, very good tires, way too much to list. This truck is inspected till 9/09. It needs absolutely nothing. Has Leer fiberglass hightop cap, and moon visor. $2500.oo These trucks need to go. If it wasn't for the fact I have the diesel, and was given a '95 explorer, I wouldn't be selling. Any reasonable offer accepted. You can see/run them anytime. I can be reached through pm/email, or call. 570-784-1710, or 570-441-2449. Thanks, Dave. |
Truck Is Not For Sale. I Cant Make Up My Mind.
Well i have some stuff from my old 05 ranger still
a snapless in the rail tonneau cover short bed styleside and a K@N air intake for the 4.0 OHC then a k@n ariintake for any year 6.0l f-250-350 make me an offer need to sell tired of looking at it |
FS: 1995 F250HD 4x4 ENGINE: 351W
TRANSMISSION: E4OD TRANSFER CASE: BORG WARNER 1356 8FT BED DUAL GAS TANKS REAR AXLE: DANA 60 LIMITED SLIP, 10.25 FULL FLOAT FRONT AXLE: DANA 50 (TTB) THE TRUCK IS IN GOOD RUNNING CONDITION. I HAVE PUT SOME MONEY INTO IT. IT HAS NEW EVP EGR SENSOR, HVAC RESISTER, NEW ECT SENSOR, NEW FRONT OUTPUT SHAFT SEAL ON THE TRANSFER CASE, NEW 195 DEGREE THERMOSTAT. ALL FLUIDS HAVE BEEN CHANGED EXCEPT FOR COOLANT. TWO THOUSAND MILE OIL CHANGE INTERVALS. THE TRANSMISSION FLUID HAS BEEN CHANGED. IT WILL NEED SOME WORK. TWO FREEZE PLUGS ON THE PASSENGER SIDE OF THE BLOCK ARE BAD AND LEAK VERY LITTLE. NEW BRASS FREEZE PLUGS ARE INCLUDED WITH THE TRUCK. HAS A SMALL BUT NOT FREQUENT TRANSMISSION LEAK, GUESSING ITS COMING FROM THE DIPSTICK TUBE SINCE IT HAS A LITTLE PLAY. THE BED FLOOR WILL NEED SOME ATTENTION. THE REAR BUMPER WILL ALSO NEED TO BE REPLACED AS IT HAS HOLES. INSPECTION GOOD TILL FEB 09. THE FRAME IS SOLID. KBB - FAIR CONDITION - $3,695 CONTACT JAMES IF YOU HAVE ANY QUESTIONS OR WOULD LIKE A TEST DRIVE 484.221.3650 ASKING $4200 OBO |
1990 F350
A friend has a 1990 F350 4dr 4x4 longbed SRW 351 5 spd. This truck was wrecked and rebuilt with a PA reconstructed title. It is in fairly good shape. Dont know the miles. The prob with it is that it wears the right front tire out rather quickly. That to me is a (slightly) bent front axle. He also said that a mounting ear? is broken off of the trans and the tailgate is missing. The guy is asking 1500.00 firm to sell it. It has not been run for at least a year. I do not need another vehicle, but I would buy it. It is in Hollidaysburg PA.
I have a front axle out of a 79 bronco that needs to go, believe its a 3.50 gear. I can email you pics if pm me. Don't know alot about this axle as I got it with a motor I just bought. Asking $150, local pickup only I'm located just north of Easton.
I have a set of 16.5x9.75 Eagle Alloys (Series 058, 8 x170mm) off of my '00 F250. Will sell for $100. They've been stored/wrapped in my basement the last 4 years, only used them for about 3 years.
I'm in the East Pittsburgh area and can meet up within a reasonable amount of miles. You can kind of see them on the truck here (wheeling in AZ) |
4 TSL Boggers for sale
I've got 4 16/35x15 TSL Boggers on 15x10 chrome wagon wheels for sale.
Tread is like new. These have NO street miles on them. The rims are so-so. I'll split them up if you only need two. $1,000 for 4 -- $500. for 2 Pick up only. I'm located just north of Northampton, Pa. -- Nick Sr. e-mail me at nicholasmonn@yahoo.com or call 610-262-3035 leave message. |
Hey guys how's it going with your stuff?
Has it, or parts of it been sold? If it has, post "IT'S SOLD" and we'll move it to the old thread. |
My post above is still valid. However, I'm not stuck on just selling them. I also love to barter. Right now I'm looking for parts for converting my '90 over to 4x4. Also looking for a reading box for it. I'm also looking for a 5r55e tranny for my '95 explorer. The only part of it I need to work is the forward clutch assembly. As the tranny in it now is a reman, but they screwed up installing of the assembly. I'm also looking for a turbo setup for the 7.3 IDI.
Any and all offers welcome. |
FREE C6 automatic tranny small block pattern
It is sitting in my way... IF you can use it come get it (15501)
otherwise It gets scrapped. I got a bunch of other 48-52 parts, 73-79 parts and 66-77 bronco parts. |
97 F250 is sold but I still have 2 sets of factory wheels. XLT and XL.
pics of them?
Super Duty
I am looking for a set of tires for my 2003 Excursion. I would like to have at least a 285/75r16. Will look at aftermarket wheel/tire combo. If someone just happens to have a 4" suspension lift I could be interested in that also. Then I will need even bigger tires. How about a BF push bar bumper for the front. Call me at 814-207-0202 Thanks.
Looking for an F150 92-96. Doesn't need an engine or transmission, but would like everything else :-X18 I'm in central PA, can travel all over to get it probably. Let me know, my dad and I are putting a perkins diesel into it if we can find a transmission and transfer case coupling.
Or a Bronco from the same generation |
