:-hijacked
Originally Posted by Sw1tchfoot
(Post 10773699)
Thanks for the picture, I didn't know how the AIR system worked.
Just looking at it, I don't think it really makes a difference whether or not you plug them. If you do, I think it would be much better to tap the hole and use a bolt to plug it. |
dlapl390 - I think you two are talking about plugging the ends vs the "middle" on the thermactor passage. He was talking about plugging where they come into the exhaust port, and you were talking about plugging at the rear of the head where the thermactor manifold hooks up. Right?
But, glad to hear that approach works as I'll be plugging the back of these D8's when I put the engine back together. Thanks. |
Thought I'd post a quick/short update here as well as in the 351W Build thread just for thoroughness: It looks like after break-in the truck will get ~13 MPG on the highway, which is exactly what it got before the rebuild and head/exhaust work. Or, to put it another way, removing the smog bump in the heads and changing the exhaust from a single with cat to a true dual with glass packs made no difference in MPG.
However, it made a significant difference in power, especially in the ability to wind the engine. Now if you are cruising at a true 65 and want to pass someone it'll go to 80 very easily and quickly. Or, if you are running slower and kick it down a gear it winds right now and you are around someone right now. And, I should point out that it is still running the 2150 2 bbl carb, which seems quite adequate now that the exhaust is flowing freely. |
