Originally Posted by Redneckfordf2502002
(Post 15009396)
Headlight relays make the stock bulbs in the stock housings brighter. It will work on HIDs or LEDs too I believe. On my 88 I am running Sylvanias (the brightest bulb made by them always forget the name) with the headlight relay and it is a huge difference.
Not sure if their is a write up or if their is anything else to it as my 88 already had it done. Trav I have no plans to put HID's in my truck, but I would definitely like to improve the brightness of the lights when I replace my housings. |
If you don't want HIDs I would look into leds with clear lens like Dixie460 on here did.
I would bet if you google headlight harness for these trucks you will find something. I personally haven't looked it up yet because I haven't gotten to that stage with the trucks I plan to do them too. Trav |
the biggest reason to do the headlight relay is to keep the current that runs the headlights from going through the switch and then melting it. it also has less resistance and in turn make the headlights brighter
Replaced my 4x4 shift linkage today. Undercoated and greased the crap out of the new one. Hardest part was removing the shift lever from the old linkage.
https://cimg1.ibsrv.net/gimg/www.for...f168106eea.jpg Hardest part https://cimg2.ibsrv.net/gimg/www.for...36bf7b5c4b.jpg https://cimg6.ibsrv.net/gimg/www.for...fbaa40e907.jpg Shift level painted with red primer... its a ford maybe I should have picked blue? |
Originally Posted by Stevaroo01
(Post 15009370)
Hey, good job! I've seen seen several people mention recently that they've created a headlight relay. And this has me curious... it appears that the primary reason for doing this is to make your lights brighter, which sounds great. But is there more to it than just a relay? Does this make them brighter with standard bulbs in stock housings? Or is this intended for use with HID's or something like that?
Also, is there a write-up anywhere about how to create a headlight relay? I'm just very curious about this whole thing. I am slowly working through my old truck and repairing, upgrading, and restoring it as I go. I intend to replace my light housings in the future just because mine are pretty worn out (yellowed and faded, moisture inside, etc.). Adding headlight relays may be something I'd be interested in doing at the same time if it's within my abilities. One major benefit of the relays (besides the brighter lights) is that it takes the electrical strain off your headlight switch. From what I've heard at least, the headlights get their power from the switch in the dash, and that switch is supposedly failure-prone. The relays will power your headlights directly from the battery instead of via the switch, so the switch shouldn't burn out. Plus, if one or both of the relays die, it takes less than 5 minutes to plug the stock wiring back in and you're back on the road. It's a nice little backup system. If you're thinking about upgrading your housings and bulbs too, I have some before and after pictures you can check out here. I did the upgrade last month, it was worth every penny. |
Changed out the thermostat, gasket and temperature sensor today. Added three accessory sockets that are powered on with the ignition on. And washed it after getting stuck on a red clay road. Oh! Enjoying this warm January weather.
Replaced the solenoid on the 90 F150 after it left dad in a parking lot broken down. Brand new solenoid and a rescheduled doctors appointment and he was good to go oh and help from the neighbor since he forgot the tools here.
Hopefully this will fix the slow start in the cold. Trav |
Last night I changed out the crusty old battery terminals with brand new ones. Couldn't even adjust the tightness on the old ones. It's a wonder the truck even was able to start!
(Post 15009370)
Also, is there a write-up anywhere about how to create a headlight relay? I'm just very curious about this whole thing. I am slowly working through my old truck and repairing, upgrading, and restoring it as I go. I intend to replace my light housings in the future just because mine are pretty worn out (yellowed and faded, moisture inside, etc.). Adding headlight relays may be something I'd be interested in doing at the same time if it's within my abilities. This is the guide I used to put my harness together: Daniel Stern Lighting Consultancy and Supply It wasn't too difficult to put together, I had mine done in a couple of hours, hardest part was soldering the heavy gauge wires together but nothing out of reach if you're confident with your soldering skills.
Originally Posted by ponykilr
(Post 15009444)
2 Attachment(s)
I decided to make a heat shield as I never liked the foil-backed insulation that came stock. I made it out of aluminum, 40ga, custom cut and shaped it. Had a friend do some welding on it to make it sturdy, ground down the welds, did some hammering, added some filler (just near the edges with welds), etched, and painted with high temp paint. First time for me working with metal like this, especially a soft metal, so I found out that light hammering made small dents. For me, best thing was a power or planishing hammer or I could have used an english wheel. Both too expensive for me to buy for one time use, so I made something using caster wheels, came out pretty good.
234,800 miles
today I took the truck into the shop.
Got the following accomplished: -Machined Front Rotors -Machined Rear Drums -Replaced PS Wheel Cylinder -Changed and bled the brake fluid Truck stops like a dream now. |
I finally got new wheels and tires on the old girl! I went with some 16x10 steel soft 8 wheels with 4 inches of backspacing and for tires I went with some 285-75-16 kenda klever Mts! Keep in mind this is one a 2 inch leveled 1995 f150 4x4
I have the links the the parts i used Wheels http://m.summitracing.com/parts/brw-997615540 Center caps http://m.summitracing.com/parts/pcw-102 http://m.summitracing.com/parts/pcw-104 http://i1338.photobucket.com/albums/...psr2vbeuf2.jpg http://i1338.photobucket.com/albums/...psgsvfkwjc.jpg http://i1338.photobucket.com/albums/...ps8i2dkcod.png http://i1338.photobucket.com/albums/...ps0xch7s9c.jpg http://i1338.photobucket.com/albums/...pso52eadfm.jpg http://i1338.photobucket.com/albums/...pshzngxsi1.jpg I love the new wheels and tires! |
While troubleshooting a problem with my dome light I found some burned/melted up wiring under the driver's side rock trim plate. A trip to the junkyard for a chunk of harness and a couple hours of soldering has everything working properly now.
https://cimg4.ibsrv.net/gimg/www.for...4a0704d1fb.jpg |
Looks good. Those fill up the wheel wells.
Originally Posted by 1993_f350_2013
(Post 15013842)
