Door locks don't work: 1995 F150
Old Jun 28, 2010 | 11:55 AM
rlh68050's Avatar
rlh68050
I just picked up a 1995 F150 4x4. It's in pretty good shape but the door locks don't work. Even the manual operation won't lock the doors. Is this the lock actuators themselves causing this? I wouldn't care if the power locks didn't work but I need to lock it up somehow.
Old Jun 28, 2010 | 12:21 PM
redlightning93's Avatar
redlightning93
Sounds like the actuators are frozen. You will probably need to remove the door panels and remove the linkage from the actuators to the locks if you do not want the power door locks to work.
Old Jun 28, 2010 | 12:26 PM
zxwut?'s Avatar
zxwut?
Open it up, clean and lube everything with some white lithium, move parts around to see if it'll free up and work. If not, find out why from there.
Old Jun 28, 2010 | 12:54 PM
rlh68050's Avatar
rlh68050
Ok, thanks. I was hoping that I could just remove the linkage from the actuators and use the locks manually. A new actuator is $100 and I don't want to spend that. I don't need power locks.
Old Jun 28, 2010 | 01:04 PM
zxwut?'s Avatar
zxwut?
Or you could just try and clean it up with some lube and see if it works?
Accessories definitely aren't necessary, but they sure are convenient to have.
Old Jun 28, 2010 | 02:08 PM
rlh68050's Avatar
rlh68050
Yes, I'll certainly try to get them working but it doesn't really matter as this is just going to be a work truck.
Old Jun 28, 2010 | 03:17 PM
USMC35thSS's Avatar
USMC35thSS
I actually had the same problem with my 95. The plastic piece that hooks up to the door lock itself cracked. I drilled a couple of holes in the plastic piece and used safety wire to keep it together. Its been going strong for about a year now. Hope this helps.
Old Mar 6, 2013 | 08:32 PM
Rob Boyle III's Avatar
Rob Boyle III
Great question!! Same problem I have!
SteveL53
Electrical Systems/Wiring
Jul 26, 2016 08:53 AM
Bubba Jones
1978 - 1996 Big Bronco
Mar 28, 2016 07:40 PM
04badford
1997 - 2003 F150
20
Dec 11, 2015 11:06 PM
Vanaddiction
17
Feb 26, 2014 07:07 PM
