390 motor mount issue 72 f-250 4x4
Old Oct 30, 2009 | 02:04 PM
GIO23's Avatar
GIO23
Hi,
I am currently rebuilding my nephews 390 engine out of a 67 thunderbird. The engine is going to be installed into a 72 f-250 4x4. The 360 that came out of the truck has 4 holes for the motor mounts, the Thunderbird 390 only has 2 and the truck motor mount does not line up. is there another mount i could use or a company that sell the retro kit. The tbird block has already been to the machine shop so I dont want to send another and waste the money. thanks giovanni
Old Oct 30, 2009 | 04:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by GIO23
Hi,
That 390 isn't from any 1967 Thunderbird, or any other 1965 or later passenger car or truck.
Ford changed the engine mount bolt holes in 1965 on all FE engines.
What you have is a 1961/64 390 block. Or...it could be a 352 if not from a T-Bird.
I cannot answer the question if anyone makes motor mounts or adapters to allow this early engine to fit in a 1965 or later car/truck.
Old Oct 30, 2009 | 09:54 PM
GIO23's Avatar
GIO23
I do remember it had c4** heads on it i can check the numbers in the morning. thanks
Old Oct 30, 2009 | 10:42 PM
orich's Avatar
orich
I had a 1955 ford 2Dr sedan way back in 1963 with a 292 T-bird motor . Well, I wanted to go faster so, I put in a 1961 390. I'm sure, I use the same motor mounts from the 292 V8 motor. So early mounts may work for yeah..my 2cents
orich
Old Oct 31, 2009 | 02:07 AM
ford390gashog's Avatar
ford390gashog
You will have to use the early style mount and modifly the perches.
Old Oct 31, 2009 | 06:11 PM
GIO23's Avatar
GIO23
Thanks must have been swapped into the tbird i pulled it from.
found these numbers on the block c4ae 6015-a
4b26
on crank c4ae-b
thanks
Old Nov 1, 2009 | 05:22 AM
jowilker's Avatar
jowilker
C4= 64. C=1960s, 4 behind it makes it 1964.
John
Old Nov 1, 2009 | 07:46 AM
NumberDummy
found these numbers on the block C4AE-6015-A / 4B26
on crank C4AE-B
C4AE-6015-A = Block Casting Number.
4B26: Block cast February (B) 26, 1964 (4).
C4AE-B aka C4AE-6303-B = C4AZ-6303-F .. Crankshaft
Fits: 1963/65 390: Ford Galaxie/Custom/LTD / T-Bird / Mercury Monterey/Montclair/Marauder/S22.
Old Nov 2, 2009 | 12:17 PM
bertha66's Avatar
bertha66
I put a 64 390 into a 66 F100, I had to make plates to bolt on to the block that would the 66 motor mounts to bolt on. It was just a flat piece of steel with holes drilled into it that would bolt to the engine and allow the mounts to bolt on.
Old Nov 2, 2009 | 05:17 PM
Ford_Six's Avatar
Ford_Six
Yup, the engine that's in my 72 F100 is an early 390, and it's the same way- plates bolted to the mounts and the mount holes on the engine.
Old May 28, 2020 | 01:57 PM
Larry S. Martin's Avatar
Larry S. Martin
1964 390 into a 1967 F-250 - Does Not Fit!
Thanks for the insight.
Had a hack mechanic in Santa Barbara fab mounts for a 1964 390 into my 1967 F-250. Trying to fix the Freeman Automotive Design mess (see attached photo) and if there is a company that makes this mounting system, please let me know. Most are for 429 engines. Thanks,
Larry
I paid for this Hack Job!
gtellenson
Oct 3, 2025 12:27 AM
Nick-1973-ford
Oct 6, 2016 04:19 PM
59 BL JNS
Jun 28, 2016 10:15 AM
fourboltmain3401
Apr 20, 2016 08:20 PM
6t6Comet
25
Aug 12, 2014 02:08 PM
