Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Dumb people are funny
Old May 9, 2009 | 12:11 AM
Snowking's Avatar
Snowking
Today on my way back from yorkton I saw a newish f150 with a tiny trailior pulled over by a DOT officer........ he was towing a Bobcat S300
I wonder why he got pulled over
Old May 9, 2009 | 12:30 AM
preppypyro's Avatar
preppypyro
Sherm, use the proper damn sized trailer at least!!
Those newfies, I swear....
Old May 9, 2009 | 04:25 PM
Fomoko1's Avatar
Fomoko1
And sometimes they`re down right annoying too.....Especially if you get caught in traffic behind them.
Old May 9, 2009 | 08:16 PM
skidooman's Avatar
skidooman
How heavy would that Bobcat be? I have towed a mid sized skid steer with my truck but not on a tiny trailer.
Old May 9, 2009 | 08:37 PM
Fomoko1's Avatar
Fomoko1
My S250 is close to 8,000 lbs with only a bucket, an S185 is probably close to 6,000 lbs.
Old May 10, 2009 | 08:18 AM
preppypyro's Avatar
preppypyro
Do you think it would be that much less? I would guess a s185 would be JUST under the weight of your s250, and the S300 would be just over.
Some people just dont realize the importance of the proper sized trailer though!
Old May 10, 2009 | 08:53 AM
skidooman's Avatar
skidooman
Tha skid steer I was pulling was in the 6000 to 7000lb range, so I wasn't over the trucks limit.
Old May 10, 2009 | 08:55 AM
preppypyro's Avatar
preppypyro
Plus Marlon, you most likely had the proper sized trailer for it too!
i guess a guy can always have to heavy of a trailer too.
Old May 10, 2009 | 09:12 AM
96sherm's Avatar
96sherm
what ...hey... it fit on the trailer, that means the truck can tow it right???
last monday i seen an '09 F450 towing a full sized excavator on a goose neck triaxle. i'd venture to say he was over weight also, but the truck was moving with traffic no problem and the truck wasn't squat much!!
Old May 10, 2009 | 10:59 PM
preppypyro's Avatar
preppypyro
Thats pretty crazy too Sherm. Full sized excavator must weigh a bit. My backhoe weighs 16-17k or so, and a full sized must be at least double that!
Old May 11, 2009 | 01:04 PM
Corner Gas's Avatar
Corner Gas
According to a few farmers around here a trailer isn't overloaded until the tires are rubbing on the fenders.
Old May 11, 2009 | 08:31 PM
Fomoko1's Avatar
Fomoko1
It can`t be those full sized large excavators I`m thinking of, they go on a very heavy duty low bed trailer, some with many extra tires under it.
Old May 12, 2009 | 08:58 AM
preppypyro's Avatar
preppypyro
Ive seen guys pull full sized excavators behind tandem axle dump trucks, on tag trailers before. Each guy i talked to said that they were at the absolute max capacity though.
Old May 14, 2009 | 12:00 AM
Duncan10's Avatar
Duncan10
S 300 must weigh over 8000 lbs. Way over what an F150 can tow anyway with a 2000lb trailer you are up to what 15000 GVCW I don't think an F150 can tow that legally anyway. Correct me if I am wrong.
A full size hoe behind an F450 the guy must be on drugs. A 35,000 lb machine behind an F450 Duh.
Old May 14, 2009 | 12:15 AM
Fomoko1's Avatar
Fomoko1
I`m pretty confident your correct and also just the standard factory hitch might not be rated for any where near that weight.
Sherm or someone else may have a better idea of what the maximum allowable limit is on an F150.
Nice to see you back on here again Duncan! Will you be able to make it to Radisson`s car show this year?
