Replacing the floor pan on a 68
Old Mar 28, 2009 | 12:42 PM
oldtexasdog's Avatar
oldtexasdog
Any one have any good tips on this as I have never done this before. Parts on the way.
Thanks
Old Mar 28, 2009 | 05:27 PM
waynaferd's Avatar
waynaferd
YES!!!
Only cut out the rust, not the entire floor pan!! Just use the new floor pan for patch panels and cut out what you need!!
I cut out the entire drivers side floor on mine, and after getting discouraged because of the cluster**** I had, I haven't touched it for 2 years.....The floors not quite even, and not quite the same depth as the pass side. I even cut the replacement pan in half before welding it in to make the fitment easier.....completey F'd....so I'm cutting it again, and gonna fix it the best I can, then cover it with insulation and carpet, and underneath will be the new cab mount and undercoating.
So again....
Old Mar 28, 2009 | 05:29 PM
waynaferd's Avatar
waynaferd
Oh yeah, and my only cutting tool at the time was a stick welder cranked up to burn thru the metal.....so use a grinder with a cut-off wheel for best results
Old Mar 28, 2009 | 06:51 PM
oldtexasdog
I have a plasma torch and a mig but just have not done this before. Thanks for the advice!
Old Mar 28, 2009 | 08:25 PM
waynaferd's Avatar
waynaferd
Also, I was in a hurry to see how bad the end result was gonna be, so some of my problem was welding it too fast, warping it in the center where I cut the piece in half.
Just put a few spot welds in one section, then a few somewhere else, etc, so the metal doesn't get too hot and warp.
Old Mar 29, 2009 | 06:03 PM
oldtexasdog
Cut small then tack. Got it--Thanks I appreciate.
Old Mar 30, 2009 | 10:56 AM
67and71_Carl's Avatar
67and71_Carl
I have done this. It's labor intensive, but not too bad. As indicated, you need to be careful of warping. I also recommend having as good a replacement part as possible. I used Dennis Carpenter parts and was very happy with them. They are made off the original die. Are you replacing the Cab Suport? I would recommend overlapping the old floor and using plug welds. I spaced mine every 1 1/2" inch, but that was overkill in retrospect. Also, use liberal ampounts of screws and nuts to hold everything in place as you weld. Fill the holes when you are done. Above all, use a MIG welder.
