302 block #'s
Old Nov 18, 2008 | 11:54 PM
speedracer54729's Avatar
speedracer54729
302 block #'s
i just bought a 302 was told it was a industrial motor. My numbers are from by the starter D VE-8015-A3 Z any help would be great
Old Nov 19, 2008 | 06:48 AM
MBDiagMan's Avatar
MBDiagMan
Assuming that you mean the numbers are on the block ABOVE the starter, that is not a familiar number. I suspect that it might be an industrial motor. That might be a good thing or there could be incompatibilties. Research this thoroughly before building a motor out of it.
Old Nov 19, 2008 | 11:34 AM
rockher_man's Avatar
rockher_man
Lightbulb numbers are on the block ABOVE the starter...
I know what your going thru brother...what happened to the 2nd digit???
This is all I could find out from MY stash of part # info...
DXXX-XXXX-X = 70's
??????????---I think we are missing "something" here...
V = X is used for special parts and Y or Z are often service parts.
XXJX-XXXX-X Industrial
BUT...I have another list that says:
V = Lincoln Continental 1961-81
so I guess we need NUMBERDUMMY to figure it out...
XXXE-XXXX-X Engine group
Basic Part Numbers:
6000-6898 Engine base assembly
8000-8499 Radiator and Grill---are you SURE about THIS one???
Suffix:
Just keeps track of runningchanges & revision levels
as parts change...
Old Nov 19, 2008 | 05:29 PM
Beanscoot's Avatar
Beanscoot
D8ve-6015-a3a
I think the casting number should actually read D8VE-6015-A3A. 8 is the only number that gives a valid small block casting number so far as I could determine. The suffix A3 vs. A3A is probably inconsequential. Here's an old post discussing this block:
https://www.ford-trucks.com/forums/5...-or-289-a.html
I can't think of what industrial use a 302 would have been put to. Perhaps the person you got it from can elaborate? If it has odd brackets and accessories that might help figure it out. Without evidence to the contrary, I'd suppose it's a car engine.
Old Oct 28, 2016 | 06:57 AM
MustangJimmy's Avatar
MustangJimmy
289 or 302
I have a old ford motor with the block number under the starter is D VE6015-A3A any idea what I have it has no number or letter after the D just a space
Old Oct 28, 2016 | 02:26 PM
Beanscoot's Avatar
Beanscoot
Almost certainly it's a D8VE-6015-A3A casting on which the "8" was set too low in the mold or covered with sand or similar.
Can you post an image?
Old Oct 28, 2016 | 02:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by speedracer54729
i just bought a 302 was told it was a industrial motor. My numbers are from by the starter D?VE-6015-A3 Z any help would be great
Block casting basic number is 6015, not 8015. 6000 group is engine related, 8000 group is related to cooling.
What is the casting numbers 2nd digit? The 1970/79 3rd digit of V is related to 429/460.
You better have another look at that casting number, because the V is Lincoln related. No Lincoln had a 302 until 1980.
Old Oct 28, 2016 | 04:33 PM
Beanscoot's Avatar
Beanscoot
From the Ranger Station, here is an image purported to be a 302:
302 ID help - The Ranger Station Forums
Maybe Ford had planned to use this in the Versailles and therefore assigned development to the Lincoln Division?
Old Nov 4, 2016 | 09:32 PM
baddad457's Avatar
baddad457
The A3A has the big Hi-Po Main caps. The 3A has the std 302 main caps. I've had hands on both versions. The A3A is basically a recast version of the 289 Hi-Po and the Mex 302 block with a few minor differences. Same iron content for all three (136 lbs)
Old Nov 5, 2016 | 01:25 PM
caly350's Avatar
caly350
Didn't you just write in a different thread the '78 Lincoln Versailles had a 302???
Modisette1990
Jun 1, 2017 08:58 PM
BeauF0RD
Apr 15, 2017 12:06 AM
Nathan511
Jan 28, 2017 12:36 PM
seschenburg
Sep 22, 2016 08:54 AM
8086ford
Feb 29, 2016 10:39 AM
