Hey guys, I have a problem. Today I was replacing my alternator on my 91 F150 5.0 4x and the bottom bolt had corroded inside the bottom hole of the alternator so bad that I had to put a 1/2 pull bar on it to break it loose and turn it. I was about half way of getting the bolt out (by cranking on that pull bar) when the alt and smog bracket broke. Now I have to either buy another bracket or find an alternative.
That being said, I found this Alternator Bracket kit and was wondering what would happen if I chose this route and didnt put the belt back on the air pump?
Based on what i have read here, you should be fine if you don't need it for inspection and if you don't have the cat. converters. If you do have the cat., removing the air pump will case them to over heat. Hopefully someone else can confirm.
I dont have my cat anylonger(headers)...dont have any inspection,,
