Humming noise during idling
Old Oct 24, 2008 | 01:15 AM
jc-well's Avatar
jc-well
On my 2000 Navi, I have a humming noise after coming to a stop (stop sign or light) and the engine is idling. I can hold the brake and press the gas a little and the humming goes away. Does that have anything to do with the idling sensor? Thanks in advance for your help.
Old Oct 24, 2008 | 08:55 AM
alloro's Avatar
alloro
Be happy, most people have to pay $40K to drive a hummer.
4.6 or 5.4 engine? 4WD or 2WD?
1. Is it just a humming noise or can you feel a vibration too?
2. Is there even the slightest lurching when you sit there in drive with your foot off the brake?
3. Does it do it when cold, hot, both?
Old Oct 24, 2008 | 09:41 AM
freeman666's Avatar
freeman666
If it sounds like bees under the hood try replacing the PCV valve in the left vacuum line..
Old Oct 24, 2008 | 12:15 PM
jc-well's Avatar
jc-well
It doesn't vibrate or anything of that nature. It's a 5.4L 2WD and it only does it when it's hot. It just hum until you press on the gas a little and it goes away. I will replace the PCV and see what it will do. Thanks for the info.
Old Oct 25, 2008 | 06:03 AM
Modified 99's Avatar
Modified 99
The power steering reservoir level could be low.
