I have a newly remanufactured Holley 1835 carb which has had an electric choke added to it. My '59 F-100 has the original electrical system in place. Where would you recommend running the positive and negative wires from the choke? No instructions came with the carb.
So there are two smaller terminals on the generator, one marked F and one marked G. I'm guessing the F terminal is the positive side. If so, I'll just run the positive lead from the choke to this terminal using a wire lug. Is there any reason I shouldn't run the negative lead from the choke to the G terminal, which I take it is the ground?
