Most likely been seen before but I changed out my fuel filter today. I checked the posts to determine what I needed before I took a trip to NAPA. I bought a fuel line removal tool and the filter. Turned out I didn't need the tool. As per the pic's I only had to pry off the two plastic clips and then pull off the lines. There is something that was not talked about, a little o-ring and washer that is inside the fitting that fell out when I pulled off the fuel line. Fortunatly the inlet side stayed intact so I was able to see how it went together. I was a fairly easy job except for hunting for the o-ring on the ground!!!
The truck is a 89 E150 van and the filter is located just about under the drivers seat on the frame rail.
