another edelbrock 1406 question...
Old May 12, 2008 | 10:30 PM
96sherm's Avatar
96sherm
almost a general carb question i guess... is there any way to figure out what the air/fuel ratio is to compare it with the chart in the edelbrock owners manual??
another thing... great idle, ***** when kicked down 3/4 throttle, stall when floored, and shudder when lightly accelerating... any hints?? i've ordered the tuning kit from edelbrock, as well as a new ignition coil just in case the old one was getting weak...
any help is greatly appreciated!!
Old May 13, 2008 | 06:33 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
An A/F meter is about the only accurate way. You can get a decent one for ~$200. For that you might consider spending a bit more and dyno tune. And a vacuum gauge in the cab can help you figure out which springs will work best.
Are you getting any surging at cruise? It sounds like you might be running a bit lean. You could try cranking the mixture screws out 4 or 5 turns to see if it fixes the shudder at part throttle - it won't idle but it should help the cruise if it's lean. If it works, reset the idle mixture and go with a richer set of rods for starters.
Where is your timing set? How much total advance and where is it all in?
Old May 13, 2008 | 07:01 PM
96sherm's Avatar
96sherm
thanks for the reply!! i'll skip the a/f meter... 200 is a bit much for something i can do by ear, but i would like to dyno it sometime...
i've narrowed the rough running to the a/t rod needing adjusting. local carb guru told me to try that.
not sure of the timing, i've got to get a timing light and check that out. thanks again for your reply!!!
Old May 14, 2008 | 08:32 PM
LxMan1's Avatar
LxMan1
You can also try a different hole on the accelerator pump rod as well.
Old May 14, 2008 | 10:55 PM
96sherm's Avatar
96sherm
thanks jimmy, i actually found a post where you had suggested that before. i did that on sunday and it cured my off-the-line problem. swapped my plugs today for something a little hotter, got an MSD ignition coil to put on tomorrow... might still check the timing, something isn't right with the part throttle calibration...
Apr 23, 2014 09:31 PM
whisler
30
Mar 20, 2011 10:03 AM
Bob_1
15
Sep 19, 2006 11:35 PM
nzabka
Apr 3, 2004 06:43 AM
mattri
Offroad & 4x4
Nov 16, 2003 04:54 PM
