79 f250 4x4 chassis mounts/rear shock mount
Old May 11, 2008 | 02:03 PM
cszeman's Avatar
cszeman
HI all,
I removed the body off my f250, but my chassis/frame mounts (ie the bracket that mounts to the frame) are quite rusted through. The new bushings would go right through the big rust hole. Plus my rear shock mount that mounts to the frame is rusted through...now two pieces. Anyone know a good place to buy these pieces from or do they need to be fabricated?
Thanks in advance!
Old May 11, 2008 | 03:46 PM
c.l.nye's Avatar
c.l.nye
the best thing to do is find a doner truck to scavenge.
Old May 14, 2008 | 11:01 AM
Hyperactive460's Avatar
Hyperactive460
try mikes truck salvage, he's a sponcer on the site, i baught both rear shock mounts, both front frame perches as well as the rear crossmembe ( where the cab sits ) from him a few years back. great guy to do business with. parts are rust free from the south. i have pics in my gallery.
Old May 14, 2008 | 11:09 PM
straightsix4x4's Avatar
straightsix4x4
I made a super heavy duty pair in a couple hours, I can get pics tomorrow if you would like. or if fabricating isn't your thing bronco graveyard has new ones, spendy though.
Old May 15, 2008 | 08:10 AM
mark a.'s Avatar
mark a.
Try sending a pm to 78_f800crewcab4x4 He's in Las Vegas & has posted that he is willing to help out with rust free parts he can get out there.
Old May 15, 2008 | 11:09 AM
cszeman's Avatar
cszeman
I would like to see the pics...
Thanks!
Old May 15, 2008 | 11:10 AM
cszeman's Avatar
cszeman
I would like to see the pics,
Thanks!
Old May 15, 2008 | 09:54 PM
c.l.nye's Avatar
c.l.nye
cszeman if you still need rear shock mounts i have a set of stock ones or you can get a set from a 80-96 f150 the bolt pattern is the same just uses a through bolt just like the bottom.
Old May 16, 2008 | 02:17 PM
4x4 Bart's Avatar
4x4 Bart
I got my body mounts off a 2wd chassis, they were easy to find and an exact match.
Old Jul 18, 2008 | 01:55 AM
cszeman's Avatar
cszeman
What size bolts did you use to bolt the mounts on?? I imagine you used a grinder to grind off the rivets?
Thanks,
Old Jul 19, 2008 | 03:14 PM
Thunderjet4x4's Avatar
Thunderjet4x4
I changed my upper shock mounts on my F250 with some old F150 mounts-identical. I forget what size of bolts I used, seems to me I drilled the holes a size up because the rivet hole was oddball size.
You can buzz the rivet head off with a grinder, but still may need to center drill it to relieve the stress. I found it easiest just to drill up to 3/8" I think, then nail it with a hammer and punch and they usually fly right out.
Old Jul 19, 2008 | 03:25 PM
Mikestrucks's Avatar
Mikestrucks
Originally Posted by cszeman
HI all,
Thanks in advance!
Hello, I have some frames sitting open (i.e. no body on them) if you need some main crossmembers or frame to body or spring hangers and shock mounts. Happy to help out if I can, Mike.
alaskawoobie
1997 - 2003 F150
May 7, 2013 03:35 PM
captain p4
Offroad & 4x4
May 28, 2007 10:23 PM
mdamico
Mar 2, 2006 08:41 PM
jmpaul
20
Nov 24, 2003 08:28 AM
oughtsix
Oct 28, 2002 01:06 PM
