Ever Heard of this?
Old Apr 4, 2008 | 11:34 PM
ElwoodMurphy's Avatar
ElwoodMurphy
Ever Heard of this?
In the summer when I run my A/C my truck looses power and seems to go into a survival mode(I picked that term up somewhere in my books). It's a 92 Flareside 4X4 with a 4.9 and a 5 spd manual. Any ideas? I have a code reader but not sure if the codes are right. Never done this before. I tried to count the blinking "CHECK ENGINE" light. I'm not even sure they told me how to hook up the code reader right.
Old Apr 5, 2008 | 12:59 AM
fmc400's Avatar
fmc400
MSEE
Well when the AC compressor engages, it places a higher load on the motor so naturally you are supposed to lose some power. How much of a difference are we talking here? When's the last time you gave it a tune up?
Old Apr 5, 2008 | 05:27 AM
5.0Torx's Avatar
5.0Torx
you realize all the chain auto parts stores have actual code readers, and will scan your ecu for free, right? why bother with the ghetto-fabulous paperclip method?
if the ecu runs in open loop when you turn the ac on its probably throwing a code. "open loop", by the way, is the actual term. not survival mode.
go get it scanned and go from there
Old Apr 5, 2008 | 10:41 AM
ElwoodMurphy
The loss of power is significant. When I say "goes into survival mode", I mean if you are close to home you can limp back home. This is a major drop in power. I haven't had more than 500 miles on a tune-up. The check engine light does come on when it happens. The truck runs fine otherwise.
Old Apr 5, 2008 | 10:50 AM
ElwoodMurphy
Yeah I know the stores will scan it but I wanted the experience and am a hands on kind of guy. Just never had a need for a scan before. I bought a plug unit from NAPA I think for around $60 and I am not sure it is sending the same codes everytime. I ran it 3 times and got different results all 3 times. I guess I'll see what the store gets for codes and compare.
Old Apr 5, 2008 | 02:04 PM
5.0Torx's Avatar
5.0Torx
i completely understand. Im the same way. If i cant build it or make it, ill buy it lol.
I just think you should go with the reputable scanner. Its not a dash against your pride! and then youre not solving problems that dont exist and potentially hurting the state of tune of your truck for no reason!
Old Apr 5, 2008 | 10:36 PM
ElwoodMurphy
I know your right, besides that I have lost my scan tool.
